Go to Post I think I have a warning label saved somewhere on my computer that says "Warning: All photos taken with this camera may be photoshopped" but I keep forgetting to put it on my camera. - MissInformation [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-02-2009, 08:57
sbrumund sbrumund is offline
FRC #2115 (M cubed)
sbrumund is an unknown quantity at this point
8 mm motor shaft to .5 drive shaft adaptor
We are looking for an coupler to go from the 8 mm motor shaft to a 1/2" drive shaft.
We will be using it for a ball thrower so both need to have a key to provide a positive lock.
We have limited machining capabilities but do not have the capability to cut key ways.
Does anyone know where an adaptor like this can be purchased?
Unread 10-02-2009, 09:24
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: 8 mm motor shaft to .5 drive shaft adaptor
Find a piece of 3/4 round steel. Drill it with an 8mm drill through then from one end half way through with a .5 in drill. Make this thing about 1.5 to 2 in long. Drill and tap for four 1/4-20 set screws. Grind flats on your shafts where the set screws contact them and you will not need the keyway.
Bruce
Unread 10-02-2009, 09:33
Brandon Holley's Avatar
I think its going to find something with those criteria:
1. Mate 8 mm shaft to 1/2" shaft (probably the most difficult due to metric vs. imperial)
2. Keyways are needed in both of these.
You may be able to make something simple, like stated above, with a set screw, or something simpler than a keyway, but it is not likely you will be able to buy a part off the shelf to meet all those specs.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
SDI-SI has several couplings available:
https://sdp-si.com/eStore/
Though none of them are metric-english couplers, nore do any have a 0.315 - 0.5" coupling combination. You may be able to get away with a 0.25" to 0.5" coupler by boring out the 0.25" hole to 8mm. Hope this helps.
GitHub
Unread 10-02-2009, 09:42
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
8mm is only about .0024 larger than 5/16". Get a 5/16" to 1/2" keyed adapter, and it'll be a tight press fit into the CIM shaft. If it doesn't fit at all, drill out the 5/16" side with a O drill (.316).
Use set screws or roll pins for the CIM motor side, unless you can find an imperial-to-metric key.
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-02-2009, 11:21
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
We found ourselves in the exact same situation. We ended up using 2 Andymark hubs. It's kind of a bulky and expensive solution, but we didn't really have machining available, and we already had the hubs laying around.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 10-02-2009, 11:37
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Here is a fantastic 8mm to .25" coupler:
We use these and have never had an issue. Very tough and reliable.
There are many styles and sizes to choose from: Here is a budget version (Plastic instead of AL).
This vendor (Automation Direct) is a FIRST supporter and KOP supplier.
(And they ship VERY fast ..)
Unread 10-02-2009, 12:04
For 25 bucks I would hope so!!! That doesn't even include shipping!
Unread 10-02-2009, 12:27
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
If you have a lathe and drill press, you can make a very positive coupler. Make the 8mm to 1/2 inch coupler of mild steel, 1 1/2 to 2 inches long. Cross drill with a 1/8" diameter drill, and press in a 1/8 hardened pin. Make the pin a little shorter than the coupler diameter, (recommend a minimum of 7/8 stock) so you can peen over the top of the hole above the pin to ensure pin retention. We have used this on 5/16 CIM motor shaft to DeWalt transmission adapter with no failure. This should see less load than that.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 10-02-2009, 13:04
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
An ugly solution might be to bolt this:http://andymark.biz/am-0320.html
to
this: http://andymark.biz/am-0077.html
--Madison--
...down at the Ozdust!
Unread 10-02-2009, 13:08
Dick Linn's Avatar
no team (Synergy)
Perhaps something like this would work? A 1/2" to 5/16" flexible coupling:
http://www1.mscdirect.com/CGI/NNSRIT...&PMAKA=8802536
Or find a steel bushing in the hardware drawer section of Lowes or a place like that. You may find one that will slip over the 8mm shaft and, with luck, will be about 1/2" outside. You might be able to split it and get it to clamp firmly in a straight 1/2" coupler (with enough Loctite).
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 10-02-2009, 14:25
AndyB's Avatar
AKA: Andy Burchardt
to
It's not ugly... its unique.
That's what I keep telling our robot at least...
Extending a cantilevered drive shaft. Madison Technical Discussion 18 04-11-2005 00:27
drill motor drive shaft attachment archiver 2001 1 23-06-2002 22:32
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
