Go to Post Umm, guys, the stacking game was last year. Toss the Genia is much more appropriate for Aim High. - Greg Marra [more]
Unread 10-02-2009, 03:36
awad1992 awad1992 is offline
FRC #1946
awad1992 is an unknown quantity at this point
radio problem (2008)
our team have a problem with the radio while training it's fall down and after that we tried to connect it but one led is on (standby one) and we tried to control with tether connection and its work successfuly
what is the problem ?
and how to solve it ?
Unread 10-02-2009, 09:52
Re: radio problem (2008)
If the radio is still working you should see
- a power light
- a wireless light flickering
- a wired connection light flickering
It sounds like only the power light is on, which sounds broken.
Try directly wiring your PC to the radio and browsing to it.
If successful, then check and verify the settings you made.
If unsuccessful, then try using the reset by pressing a paper clip into the reset hole and holding it until the power light turns orange.
If it's really broken then the reset might not work either.
[OCCRA]: Radio Problem Mike Martus OCCRA 0 16-10-2007 18:31
Radio Problem - Firmware? Tanner Control System 7 30-05-2007 09:59
Radio problem comwiz7 Programming 2 31-01-2007 23:05
Radio Problem on FRC TuaMater Control System 4 26-01-2006 07:32
radio problem Anton Control System 1 19-02-2005 12:22
