Re: For those who are skeptical about propellers - Team 2526
Think of all of the analysis that went into the design of that engine to ensure survival from such a catastrophic failure. The FAA and other aerospace agencies require proof that the design is robust, hence the analysis is backed by this very dramatic (and expensive!) test. I'd be interested in seeing what came out of the the exhaust of that engine. I bet it wasn't pretty... BTW, I didn't post this to discourage propeller advocates for robots. I just want them to see what kinds of challenges engineers sometimes encounter. |
Some of the coolest testing we do is this test and the bird strike test, which basically involves shooting ducks at an engine running at full power. As was recently proven in NY, it's a good thing we do it. A friend of mine in the test department designed the equipment to do our most recent bird strike test. As an MC and announcer...I hope the safety restrictions are very tight on prop-driven robots. Otherwise, I'll be announcing from outside. |
As a scorekeeper about three feet from the edge of the arena, who has the added disadvantage of sitting down most of the time and is therefore less mobile, I couldn't agree more.
I agree that that needs some serious protection. Don't underestimate the energy in large diameter spinning objects.
Perhaps you could make a ducted design that turns with the blades. Then you would get more performance, while reducing the chance of pieces coming out of the fan space. |
Check out the protection requirements in Team Update 11.
Only problem is that the update 11 doesn't have any specific requirements. It gives an example of a safe setup. It does not state any need for this particular setup. I personally won't feel that this is adequately covered until they specify max blade size, max rpm, and mandatory specific protective equipment. Any less and it will be too ambiguous.
#7
I'm not sure that they want to specify those items. They've already spec'd the bumpers to death, so it's either "Do we REALLY want to go farther?" or "Why stop there?". Judging by team reactions to the bumpers, I'd guess the former. I could be wrong. If they do specify one thing, I would say they should do specific minimum protective equipment, possibly with relation to the size of the prop and the speed. |
#8
Also, I know it is the blade size that makes it dangerous. I also know it isn't the rpm that makes it dangerous. Lets compare to electricity. The current alone won't kill you and voltage alone won't kill you. It has to be together. However, there are standards for both. If nothing else, they could set up a simple formula that would allow for various rpm/diameter possibilities while still restricting the real danger. |
#9
I have to ask: How do you draw that conclusion? Sorry, but I just don't see it. They just say, this is one example of a safe design, and we expect comparable ones. They don't say what it's in respect to, just that it has to be comparable. The design given is for a general propeller, that's it.
#10
Note to zrop: Good luck meeting all the updates' standards. |
#11
Unfortunately, there is no simple formula that makes a prop of a specific size safe at a specific RPM. There are many factors that go into max prop RPM. While diameter is one of the factors there are others such as composition of the prop (wood? Nylon? etc ...) as well as pitch, and design (Master airscrew, APC, etc). What is safe for one type is dangerous for another. All props should have a specification sheet that will tell Max RPM for that prop. I would expect teams to have a safety margin built in so that the prop cannot ever exceed that speed (In fact I would stay well below the manufacturers recomended max RPM). Again, teams will need to prove that their design is safe and that the protection they have put in will work in the event of a catastrophic propeller failure. Anything less should not be allowed on the field. |
#12
To be picky on this item, it's the current. That is why GFI devices are calibrated at current only. Voltage causes current to flow so that is why it is often labeled "Dangerous". A person with highly conductive skin and tissue will cause a greater current to flow than a person with poor conductivity for the same applied voltage.
#13
As to Team Update 11, there is three significant specifications there. The prop must be protected by a 1/4" mesh. The shroud needs to be at least 16 guage aluminum and it's length should be 1/2 of it's diameter. Those are at least easily determined by your inspector.
#14
Zrop & others, any updates? Do you guys have any automation built-in, i.e. automated yaw functions to keep you going straight, etc?
I can see that you guys are putting much effort into the design of the props, and are experimenting to get the maximum bang out of the props. This is the process that FIRST loves to see. I remember seeing a team from Florida doing a prop design -- anyone remember who they are? Assuming good safety practices, I definitely look forward to seeing this in person! (Even if bumper impact forces wreak havoc on a blade who's tip is spinning over 200mph ) |
#15
Currently we are working on replacing our props with a similar 3-prop version of the one shown. The good news is that mostly everything is mounted and working to some extent (just needs a little tweeking). The bad news is that something happened with our computers causing a lot of our code to get erased or damaged (i don't know exactly what happened). I was actually talking with some of the people are Superior Tools who are machining some stuff for us and one of the guy is a model plane enthusiast, and i started talking with him. He actually recommended a 3-prop blade for low speed high torque. He also mentioned that those props we were using are so strong that its actually illegal to make props bigger than 16 inches (somewhere around here) out of that material, and he was saying how the only thing that would break them would be foreign objects coming in direct contact. He said that sudden changes in force due to collisions would have no effect on them or cause them to break and same with vibrations. He also mentioned that little objects like nuts and bolts and washers probably won't have to much effect on the prop its self, but its best not to find out (it may just turn that nut into a bullet). As for the safety part, we are planning on having 2 cages, the first one as shown on the first page, will be used to keep large objects (mostly orbit balls) away from the props, then inside of that cage will be the aluminum housing and mesh. I am not sure if this has been said yet, but in addition to being prop driven, we have the option of a wheel drive. We are using a modified bike gear where it will freely spin if the speed surpases the speed its being driven at, we hope this combined with the props will allow for faster acceleration (what we were lacking only prop powered). Well its time to pull the all nighters to get this thing working, tomarrow i think we will be ready for the triblade + driven axle test to see what kinda performance we get out of it . Best of luck to all teams in this final week |
| Fans/Propellers - Are you doing them? | Greg Peshek | General Forum | 15 | 06-02-2009 19:50 |
| To those who are officers/admins here... | synth3tk | General Forum | 3 | 26-09-2008 07:06 |
| For those who lack dedication... | Pi Is Exactly 3 | Regional Competitions | 19 | 09-02-2005 21:26 |
| Some good humour for those who are bored. | Frank(Aflak) | Chit-Chat | 0 | 09-12-2003 19:11 |
| For those who were wondering... | Nate Smith | Championship Event | 2 | 22-04-2002 17:25 |
