Go to Post FIRST isn't chaotic; the rest of the world just moves in slow motion! - StephLee [more]
Unread 10-02-2009, 10:35
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
Driver Station Digital Outputs
Anyone know how much current the DS outputs can sink or source??
tom lafleur
mentor team 812
Unread 10-02-2009, 10:48
Re: Driver Station Digital Outputs
See section 3.1.6.2 of the control system manual.
Unread 10-02-2009, 10:50
See http://www.usfirst.org/frccontrolsystem and Chapter 3 Component Data Sheets of the Control System Manual.
Originally Posted by 3.1.6.2 Driver Station Digital Outputs:
The DS digital output pins are driven directly by 5V transceiver (SN74LVC4245A device). Be sure to use caution as each pin can source/sink more than 40mA. It is possible to damage the device if too much current is driven on a single pin or the total current supplied by the device on all pins is excessive. Best practice should be to use a limiting resistor to prevent external loads from drawing excessive current, especially for LEDs, be sure to use a series resistor to limit the current.
Driver Station Digital Input Lord_Jeremy FRC Control System 2 09-02-2009 23:06
Digital Outputs on the Driver Station with C/C++ Bongle C/C++ 6 26-01-2009 15:45
driver station digital outputs DustinB_3 FRC Control System 0 24-01-2009 11:29
Using driver station digital inputs Japper FRC Control System 6 19-01-2009 20:01
Interrupt on driver station digital input Nameless Programming 9 04-12-2008 16:55
