Go to Post Perfection is less about effort or skill than it is about having a clear and limited goals. - SoftwareBug2.0 [more]
Unread 09-02-2009, 16:45
finman's Avatar
finman finman is offline
Programmer
AKA: Chris Finley
FRC #0888 (Robotiators)
finman is an unknown quantity at this point
relay device reference?
is there a way to create a relaydevref similar to joystickdevref so that i can reference the device globally?
"Red goes to black, right guys?" ~Mike Mascaro: Our Fearless Leader
Unread 10-02-2009, 11:51
finman's Avatar
Programmer
AKA: Chris Finley
Re: relay device reference?
nevermind, i figured it out
Unread 10-02-2009, 12:00
In that case, please share with the rest of us.
Unread 10-02-2009, 16:42
finman's Avatar
Programmer
AKA: Chris Finley
there may be a better way to do this, but i was able to do so as follows(this should work for other devices as well as relays):
-place the "open relay" vi wherever you need it e.g. begin
-right click on the device reference out terminal and select create>constant
-cut and paste the block created into the global variables vi
-you should now be able to access this from the robot data in bundle
please let me know if you have more questions; having a global reference actually made the relays work for me, they had not been doing so previously
-chris
Unread 10-02-2009, 16:56
That procedure certainly works. You can also open up one of the subVIs for relay and copy the reference control or indicator. Return to your VI, paste, and connect to the connector pane.
Greg McKaskle
Unread 10-02-2009, 17:59
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
I just figured that out like yesterday, until then I was doing what finman was. Oh well, as long as it works.
Twitter Profile
cim reference table bensamra34 Technical Discussion 0 16-01-2008 19:57
Fastener reference Dick Linn Technical Discussion 12 17-06-2007 16:05
IFI Reference Guides MikeDubreuil Control System 1 10-01-2006 12:13
ME reference manual Gdeaver Technical Discussion 10 06-12-2005 12:42
reference manuals sciguy125 Career 11 05-09-2005 12:31
