Go to Post The thrills of a heroic repair, a well deserved award, a compliment on our efforts, the growth of our team members, making new friends.... These can make a memorable and exciting FIRST regional as much as a close match. - Mark Pierce [more]
Unread 10-02-2009, 13:54
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: Static warning!!!
As I said this is for testing only for us. The rule says that the only contact with the floor must be with the wheels provided in the kit.
Unread 10-02-2009, 13:59
Again I ask: what rule? So far as I can tell, neither the manual nor the GDC's Q&A responses make a static drain wire illegal.
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Actually, that's not what the rule says. You'll be safe if you use this simplification but it's not technically accurate.
Russ
Unread 11-02-2009, 11:07
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Does this rework thing solve the problem or should teams still take other precautions?
Unread 11-02-2009, 11:13
Should solve the problem but other precautions wouldn't hurt. It's always good practice to ground yourself before working with/around electronics.
Russ
Unread 11-02-2009, 22:56
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
Thank you. I need to show this one to the rest of the team. It took me a day to convince the team to mount the CRIO on non-static materian (wood). They didn't believe the frame would carry a charge.
Unread 12-02-2009, 10:22
<R41> should have convinced them in a matter of seconds.
Static Cling?? orelinde Electrical 17 27-02-2006 17:33
Static Variables amateurrobotguy Programming 8 04-03-2005 00:40
Static Electricity JeffO Championship Event 5 19-04-2004 11:04
Static on the HDPE Al Skierkiewicz Technical Discussion 60 12-03-2003 17:52
Static Electricity archiver 2001 12 24-06-2002 00:34
