Go to Post (Don't ask why a retired FIRSTer is on CD, it's a twelve step process kind of thing) - Matt Krass [more]
Unread 10-02-2009, 15:16
Alex_2487 Alex_2487 is offline
AKA: Alex Korpi
Alex_2487 is an unknown quantity at this point
Send a message via AIM to Alex_2487
Compressor won't start
i'm using this code and everytihng works on our robot but the compressor won't start. here is my code any help would be appreciated. thanks in advanced
//2009 Sayville High School Robotics Code
//Uses a 2 motor tank drive system with 2 sim motors wired to jaguars
//has a front roller using a cut in half fisherprice motor wired to a victor
//has a beater bar system power by 1 sim motor wired to a victor
//has a compressor which uses standard compressor class to run during match
//has 2 solenoid that on run together with a pully system used to dump balls
//drive joysticks are standard usb joysticks fron kit of parts
//third joystick is used to control frontroller,beatbars,and both solenoids
//INPUTS
//left drive motor(jaguar) - pwm1
//right drive motor(jaguar) - pwm2
//beater bars(victor) - pwm3
//front roller(victor) - pwm4
//Compressor1 - spike relay(relay1),pressure switch (digitalinput1)
//Solenoid 1 -solenoid 1
//Solenoid 2 - solenoid 2
//Left Joystick - USB 1
//Right Joystick - USB 2
//NOTES
//victor can only run as slow as 10%
//jaguars can run as slow as 3%
//drive function is (speed,turn)
//setleftmotorrightmotorspeed function is (leftmotor,rightmotor)
//instead of speeds being 0 to 255(binary) speed has been normalized to be -1.0 to 1.0
#include "WPILib.h" // include the WPI robotics library
class RobotDemo : public SimpleRobot //class being used is simple robot
//Global Varaibles
RobotDrive myRobot; //Robot Drive defines the 2 drive motors
Joystick LeftJoystick; // Defines Leftjoystick
Joystick RightJoystick; // Defines RightJoystick
Joystick ThirdJoystick; // Defines Thirdjoystick
Compressor *Compressor1; // Defines compressor
Solenoid *Solenoid1,*Solenoid2; // Defines Both soleoinds
Victor *FrontRoller, *BeaterBars; // Defines FrontRoller and BeaterBars
public:
RobotDemo(void): // inizalation code
myRobot(1, 2), // drive motors are in pwm 1 and 2
LeftJoystick(1), // leftjoystick in usb port 1
RightJoystick(2), // rightjoystick in usb port 2
ThirdJoystick(3) // thirdjoystick in usb port 3
GetWatchdog().SetExpiration(100);
Compressor1 = new Compressor(1, 1); // compressor spike is in realy 1 and pressure switch is in digital input 1
Compressor1->Start(); // compressor will run when not fill during autonomous and operator control mode
Solenoid1 = new Solenoid(1); // solenoid1 is in solenoid module port 1
Solenoid2 = new Solenoid(2); // solenoid2 is in solenoid module port 2
FrontRoller = new Victor(3); // front roller motor in pwm 3
BeaterBars = new Victor(4); // beater bar motor in pwm 4
void Autonomous(void) //start of autonomous
GetWatchdog().SetEnabled(false); //watchdog is disabled durning autonomous
myRobot.SetLeftRightMotorSpeeds(1.0, 1.0);
Wait(2.0);
myRobot.SetLeftRightMotorSpeeds(-1.0, 1.0);
Wait(2.0);
myRobot.SetLeftRightMotorSpeeds(1.0,0.0);
Wait(2.0);
myRobot.SetLeftRightMotorSpeeds(0.0,0.0);
void OperatorControl(void) //start operator control
GetWatchdog().SetEnabled(true); // watchdog is enabled during operator control mode
while (IsOperatorControl())
GetWatchdog().Feed();
myRobot.TankDrive(LeftJoystick,RightJoystick); //2 Motor Tank Drive
if (ThirdJoystick.GetRawButton (1)==1 ) //if leftjoystick button 1(trigger) is click
Solenoid1->Set(true); // then solenoid1 will be out
Solenoid2->Set(true); // and solenoid2 will be out
else // if button 1(trigger) is not pressed
Solenoid1->Set(false); // solenoid1 will be in
Solenoid2->Set(false); // and solenoid2 will be in
if (ThirdJoystick.GetRawButton (3)==1 ) {
BeaterBars->Set(0.0); }
else
BeaterBars->Set(1.0); }
if (ThirdJoystick.GetRawButton (5)==1 ) {
FrontRoller->Set(0.0); }
else
FrontRoller->Set(1.0); }
START_ROBOT_CLASS(RobotDemo); // start robot class and starup library(run program)
Events
2009 SBPLI Long Island Regional
2008 Deer Park Invitational, Championships- Galileo Division, SBPLI Long Island Regional
Awards
2009 Long Island Semifinalists
2008 Deer Park Invitational Finalist (353,1546), Long Island Regional Champion (2010,102),Highest Rookie Seed, Rookie Inspiration, Best Website, Website Excellence Award
2009 Record(2487): 5-9-1
2008 Record(2487): 23-10-3
Overall Record(2487): 27-19-4
www.wbsts.com/gnomes.html
Unread 10-02-2009, 15:28
Re: Compressor won't start
Try putting a manual switch on Digital Input 1 to rule out a problem with the pressure switch.
You do have the compressor's Spike connected to the Relay 1 pins on the Digital Sidecar, right? Watch the LEDs for that relay output to see if they are changing as you expect.
Unread 10-02-2009, 15:42
AKA: Alex Korpi
We have the spike connected to relay 1 on the sidecard. i'll take a look at the lights and try using a manual switch. also the compressor works when plugged into a battery.
Events
Awards
Unread 12-02-2009, 12:26
AKA: Alex Korpi
the led lights on the relay change when u use a switch instead of the pressure switch but the compressor still wont start.
Events
Awards
Unread 12-02-2009, 13:28
Kruuzr Kruuzr is offline
Mentor - electrical, software
AKA: Steve Cote
FRC #1922 (Ozram)
Kruuzr has a spectacular aura aboutKruuzr has a spectacular aura about
Make sure that the PWM cable for the spike relay is not plugged in 1 pin off on the digital sidecar. If you don't shave off the little tab on the side of the new PWM cables, it is almost impossible to plug them in right. And even if you do shave it off, it's an easy mistake. Let's just say I'm telling you this from experience
Also, make sure you have the polarity of the power wires going into the compressor spike correct. If the LED on the DSC lights and the compressor doesn't come on, it's either a)bad DSC, 2)bad/wrongly installed PWM cable, 3) bad/miswired Spike.
Steve C.
Unread 12-02-2009, 16:03
AKA: Alex Korpi
all the lights on the spike don't turn on. we are having the same promblem with our solenoids too. we wired them to spike like last years.
Events
Awards
Unread 12-02-2009, 16:41
AKA: Alex Korpi
thanks for all the help. it turns out the relay ports on our digital sidecard didnt work and we had a bad fuse
Events
Awards
Wind River won't start radau C/C++ 6 19-01-2009 23:09
Won't Download! diaperrash89 Programming 4 25-10-2007 23:02
It won't build anymore cgront Programming 3 02-02-2007 17:26
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 11-02-2004 12:24
