Re: Digital Inputs + Auton?
Switch 1 is getting plugged in to positive-negative end signal; the other six are only getting signal because all switches are grounded together. However, the only switch used in the code is switch1
(Thank you by the way!) Last edited by Straberrie : 10-02-2009 at 15:40. |
| Digital Inputs? | Straberrie | Programming | 4 | 15-02-2009 01:47 |
| Using Interrupts on Digital Inputs | Analog | C/C++ | 6 | 03-02-2009 23:05 |
| Digital Inputs | KRibordy | C/C++ | 5 | 25-01-2009 00:35 |
| Auton digital input | ten3brousone | Programming | 7 | 20-03-2005 22:23 |
| Analog vs Digital inputs? | f22flyboy | Programming | 8 | 08-11-2002 22:18 |
