Go to Post The Robot Alliance Project is perpetrating the government shutdown? I KNEW robots would take over the world! - BBray_T1296 [more]
Unread 10-02-2009, 16:52
Re: Ground Clearance
Originally Posted by aznkazoon View Post
So our builders were wondering what the minimum ground clearance is.
-I also heard that the field will be uneven, if anyone knows if this is true or not, I would also like to know.
Minimum ground clearance: None. Just keep everything other than rover wheels off the ground if there is a chance of traction being added.
Uneven field: only where the carpet and regolith meet. There will be a slight unevenness due to the fact that the regolith is on top of the carpet. 1/8", IIRC. It'll be covered by fiberglass tape.
Ground Clearance CDH Jeff Technical Discussion 5 21-01-2009 14:58
pic: Virginia's rear ground clearance falconmaster Extra Discussion 7 25-01-2008 23:31
Think about Robot Ground Clearance ggoldman General Forum 12 10-01-2007 08:22
how important is ground clearance? Zippiot Technical Discussion 10 16-02-2005 11:56
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 15-02-2005 17:02
