Go to Post West Coast Drive is best coast drive. - [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 10-02-2009, 17:30
ptan ptan is offline
Paul C. Tan., P.Eng.
AKA: Paul Tan
no team (Bolt Action)
ptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to beholdptan is a splendid one to behold
[FTC]: Caution - Tetrix Motors burn out on Stall
In case you haven't found out the hard way, stalling a Tetrix motor for even 2 seconds will burn it out.
Be CAREFUL even if you are only running it at 25% power. IF YOU HAVE PID control enabled (RobotC - PID box checked), the PID system will detect a stall and boost the power up to 100%. At which point after 2 seconds, you have a fridge magnet/paper weight instead of a motor.
I ended up making the rule for the team that we will NOT use the built in PID control for the robot. The danger of burning out a motor is just too great. (after burning out two motors, I had no choice)
Coach - FTC Team 27 (now retired)
Coach - VRC Team 2027 (now retired)
Past Mentor - FRC Teams 188, 610, 1009, 2634
[FTC]: Attaching Tetrix to LEGO motors. ttldomination FIRST Tech Challenge 5 23-01-2009 22:13
[FTC]: Use of VEX in Tetrix ttldomination FIRST Tech Challenge 7 11-01-2009 17:42
[FTC]: FTC Tetrix Extra Parts Team 288 FIRST Tech Challenge 2 22-10-2008 18:30
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
