Go to Post Different strokes for different folks. - Madison [more]
Unread 10-02-2009, 17:46
Dr. Manhattan Dr. Manhattan is offline
Atomic Reconstruction
AKA: Joe Bakke
FRC #2521
Dr. Manhattan is on a distinguished road
Send a message via AIM to Dr. Manhattan
Re: Festo Solenoid Doesn't Work
Originally Posted by camtunkpa View Post
I will second the pins 1&3 connection. 222 had the same exact problem on both of our festo valves.
Just to clarify, negative goes into 1, and the positive into 3?
Unread 11-02-2009, 16:42
camtunkpa camtunkpa is online now
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
I don't remember what the polarity is, but I do remember pin 1 is correct as shown on the connection diagram from festo. We just had to move the wire from pin 2 to pin three
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 11-02-2009, 17:09
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
My Festo would not work so i just switched to a SMC single solenoid and it works fine. I am going to change the wiring on the festo to see it that was the problem.
Unread 11-02-2009, 18:26
AKA: Joe Bakke
FRC #2521
Team 2521 can also confirm that switching to 1 & 3 worked. One of them didn't, but we assume that that's because it was DOA.
Unread 11-02-2009, 20:20
nevereverregret's Avatar
nevereverregret nevereverregret is offline
AKA: sammy
FRC #2869 (One Small Step)
Team Role: Student
nevereverregret will become famous soon enough
Send a message via AIM to nevereverregret
our festo valves wouldnt work at all... we gave up and are using last years and now they wont work either
"How do you join.
You show up.
How do you get responsibility.
You take responsibility."
Unread 11-02-2009, 20:33
AKA: Joe Bakke
FRC #2521
Are you getting any sort of LED response on the breakout or festo itself? Also, make sure that you're breakout is plugged into cRIO module 8 in NI 9472 or it won't work. If you have any more questions feel free to PM me.
Festo Single solenoid JP_1163 Pneumatics 4 24-02-2006 15:07
Festo solenoid wiring? computhief263 Pneumatics 1 15-02-2004 12:25
festo solenoid maxgebhardt Pneumatics 19 21-01-2004 23:06
Festo valve.... why wont it work? CHSguard72 Pneumatics 3 08-02-2003 19:07
sensor doesn't work PBoss Programming 7 29-01-2003 18:39
