Go to Post In any case, don't beat yourself up over it. Only 24 teams get to play in elimination rounds. Sometimes you're in the 24, and sometimes you aren't. - jgannon [more]
Unread 10-02-2009, 18:13
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: Still can't get the camera to track
I might be wrong, but I think Jill wants to turn the whole robot instead of a turret. If so, you could just take the servo positions it calculates, subtract the ange that the program thinks is center, and turn your robot in the direction of the sign. If it's negative, turn right. If it's positive, turn left. You could use a set speed to turn at, or you could scale the degrees to motor speeds. Have a deadband so that once the value gets close to zero, the robot will stop turning.
Just a couple of thoughts off the top of my head, trying to think of the easiest way to do it.
Twitter Profile
Unread 15-02-2009, 15:57
Chris1228 Chris1228 is offline
FRC #1228
Chris1228 will become famous soon enough
can you submit example code on how to do this for us visual learners?
Unread 15-02-2009, 16:31
Chris3632 Chris3632 is offline
FRC #2884
Chris3632 is an unknown quantity at this point
this is what i have, but i need to attach an encoder because, the code resets itself and it keeps tearing my cables apart. how do i attach an encoder to this?...
http://tinypic.com/view.php?pic=25uu1qs&s=5
What if we want to use the camera to track orbit balls? Bryan Herbst General Forum 10 12-01-2009 21:10
can't get joystick right with the motor coolguybigt Motors 1 16-02-2007 10:20
AAH I'm spazzing out because I can't get our camera to do anything!!! JBotAlan Programming 23 14-02-2007 04:20
[RCU]: Can't get into the chats? Julia Magoolia General Forum 0 12-06-2005 13:28
