Go to Post Define "surgery". I think we have enough close calls with "surgery" as it is. Thank god for disable dongles. - geeknerd99 [more]
Unread 10-02-2009, 18:44
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Ground Clearance
There may be some slight imperfections in the liner or the carpet underneath it, so you don't want to plan on extremely small clearances. The field surface itself is pebbled, but if you're trying to hug the ground so closely to have that be a difference, I'd say you will be having other problems with your clearance. You can't design so closely that the slightest bend in your frame from a collision means next round you're scraping the ground.
(since 2004)
Ground Clearance CDH Jeff Technical Discussion 5 21-01-2009 14:58
pic: Virginia's rear ground clearance falconmaster Extra Discussion 7 25-01-2008 23:31
Think about Robot Ground Clearance ggoldman General Forum 12 10-01-2007 08:22
how important is ground clearance? Zippiot Technical Discussion 10 16-02-2005 11:56
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 15-02-2005 17:02
