Re: Ground Clearance
Scott at Sonic tried that from underneath, but it just pulls away over time. I think it will need to be addressed from the top, but they may have come up with something better... YMMV...
They are taping it down from the top, they also have 50' long rolls to minimize seams.
The material is 3/32" thick as well I believe. 1/2" of ground clearance will be sufficient on the actual field I imagine. |
Hmm... a little hard to get out of that wording, but the edges will be taped down with gaffers tape (The same kind of tape used on the carpet seams for the previous years) and the seams between the three pieces will use the fiberglass tape. |
The GDC needs a grammarian to check their work... |
#7
We have about 1/4" clearance, and regularly wander off our little patch of regolith. We get back on without problems. We haven't experienced the curling on the edge of the glassliner material though, so hopefully that's not an issue at the competition.
| Ground Clearance | CDH Jeff | Technical Discussion | 5 | 21-01-2009 14:58 |
| pic: Virginia's rear ground clearance | falconmaster | Extra Discussion | 7 | 25-01-2008 23:31 |
| Think about Robot Ground Clearance | ggoldman | General Forum | 12 | 10-01-2007 08:22 |
| how important is ground clearance? | Zippiot | Technical Discussion | 10 | 16-02-2005 11:56 |
| pic: Ground Clearance (or the lack thereof) | ahmed | Robot Showcase | 14 | 15-02-2005 17:02 |
