Re: Startup Delay, Effects Everyone?
yep we see this issue also, i wonder what they will be doing about it...
Thank God! Will sort of... Its a bad issue, I guess its like finding out your not the only one with a fatal disease......
The delay is caused mostly just by the fact that the control system is so much more complex than last year's--for one, the cRio has an actual operating system. There's also a lot more paralell processing going on, which means that in order for the robot to perform all its functions, all the coprocessing devices need to be booted up, which for my team is the camera, bridge, and DS, in addition to the cRio.
I have been wondering how they're going to manage this at competitions--at the minimum, we'll be wating for the (significant) amount of time it takes the DS to boot since it'll be off until we plug in the competition port. |
Not sure if this is the case, but I think a lot of the wait is due to the Linksys router. At competition the router will remain on.
With the DS on with two joysticks, it takes ~30sec for our system to become responsive. I've never tested with the DS/router off, but those both take some time to load. I can believe that from a totally cold boot of everything ~60sec will be normal.
Ours starts up in 30 seconds.. haven't timed the bridge connecting..
It's gotten to the point where I tell people to not turn it off unless extremely important D= |
#7
I have now read and/or heard quite a few people saying that the startup time will affect the way matches are run at regionals.
Maybe I'm just misremembering, but I don't think it will be that big of a deal. Introductions take about this long anyway. It just means that it is even more important than before that everyone remembers to turn their robot on before leaving it on the field. |
#8
Will even if it only overflows 5s into auto, that leaves only 10s of normal operation.
Its important that they have some kind of tracker that makes sure all the robots become responsive before the match is started |
#9
The Field Management System (FMS) software keeps track of a number of robot readiness parameters so they can make sure that all robots are properly connected and ready to go before the match is started.
#10
This is correct, FMS won't even let the scorekeeper start a match unless the DS is reporting to FMS that the robot is ready to start (which means you're synced up and ready to go) unless the scorekeeper bypasses you which will keep your bot from running. We'll know by the end of this weekend (Suffield) how boot times will effect student tournaments. FTA training last weekend rotating 12 robots in and out of the arena seemed to have no problem with the boot times, but like mentioned, if someone forgets to turn on their robot or some other issue like you guys accidently hit your estop which will require you to power cycle the robot to clear the estop, those kinds of things will eat up tournament time.
#11
| Ground Effects...Legal...Helpful? | dangell | Technical Discussion | 1 | 10-01-2009 23:38 |
| FAHA: The Effects of Vex | Beth Sweet | General Forum | 13 | 05-07-2008 13:56 |
| CMUCam 3 second startup Delay? | Chris_Elston | Programming | 4 | 19-02-2006 09:33 |
| Everyone come visit the gravesite(everyone please read) | archiver | 2001 | 2 | 24-06-2002 00:44 |
| Text effects in 3DS Max... | Ranma | 3D Animation and Competition | 6 | 28-02-2002 21:56 |
