Go to Post FIRST is like pizza. You and I may like different toppings, but in the end it's still delicious pizza. - Billfred [more]
Unread 10-02-2009, 21:53
m3rc1l3ss m3rc1l3ss is offline
FRC #1178 (DURT)
m3rc1l3ss is an unknown quantity at this point
Full solenoid controll off of one joystick button?
I have spent a few hours trying to figure out this problem, and am now thinking it best to ask for help. My problem is this: How to fire both sides of a solenoid with consecutive clicks of a single button. So far I have only been able to make it so one button fires a side of the solenoid and a second button fires the other side. At the moment, my team is using the basic framework, but there are plans to switch over to the advanced prior to ship date.
I had been thinking about using a case structure for this, until I realized that if a joystick button was feeding in, it would only read true as long as the button was depressed. If there is a way to just switch a case to true when a button is pressed and then go to false when depressed again, I know what to do from there.
Unread 11-02-2009, 01:37
s0crates s0crates is offline
s0crates is on a distinguished road
Re: Full solenoid controll off of one joystick button?
Here's a VI that I puzzled out over a few days - it takes a lot longer when you're somewhat new to a language. I'm sure there are more efficient ways, but this works.
The single input is a boolean - it could be from a joystick button or anything else - and the output toggles when the input changes from zero to one. btw its meant to be used as a subVI.
-jonathan
Unread 11-02-2009, 02:06
FRC #1178 (DURT)
Wow, thank you, that is the exact thing that I was trying to figure out how to do. I will test this out tomorrow
joystick button furiousgeorge Programming 5 07-02-2009 15:57
How do I program a relay to turn on and off by pressing a button on the joystick? eweathers NI LabVIEW 4 28-01-2009 22:34
Programming a joystick button... programmr Programming 2 05-01-2009 16:13
More than one joystick from one port Jmoo Programming 3 26-06-2003 18:01
Two Pneumatics off one Double-Solenoid Valve GrahamS314 Pneumatics 5 24-02-2003 23:49
