Go to Post We win as a team and lose as a team. - Zuhaib Ali [more]
Unread 04-02-2009, 20:54
PHSRobotics PHSRobotics is offline
FRC #2135
PHSRobotics is an unknown quantity at this point
Exclamation Errors on LabVIEW
Alright our team is trying to program the shooter that erin's brother designed and said that we needed. We keep getting errors and no matter what we change or move, the error remains.
Error -44085 occurred at Loaded FPGA has incorrect version or revision. Library expecting Version 2009, Revision 1.0.0.
That is the error.
HELP!!
p.s. Erin's our Captain
Unread 04-02-2009, 21:33
Re: Errors on LabVIEW
You need to update the firmware on the cRIO with the latest Update 3.
Use the FRC cRIO Imaging Tool and format the controller with v11.
Unread 04-02-2009, 22:08
FRC #2135
Exclamation Re: Errors on LabVIEW
We already did. When we run it, we are only running the program on the laptop, without the cRIO connected. Is that a problem?
Unread 04-02-2009, 22:36
Originally Posted by PHSRobotics View Post
Is that a problem?
Yep, there's no FPGA on your PC.
Unread 05-02-2009, 14:03
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
Here is the issue, I think:
the cRIO has the latest image, (v11). LabVIEW, though, is not upgraded to version 3.0a. You need to install http://joule.ni.com/nidu/cds/view/p/lang/en/id/1180 . There is another 3.0 installation, but that is to update WindRiver.
Edit: Oh, never mind that won't help you if you're trying to run it on the PC. But if anyone else receives that error while trying to run the program on a cRIO, chances are the FPGA image and LabVIEW are not on the same update.
Unread 10-02-2009, 13:31
FRC2476 FRC2476 is offline
FRC #2476
FRC2476 is an unknown quantity at this point
We are also getting error 44085--it appeared seemingly spontaneously and we can no longer run any programs.
We have version 3.0A of Crio and v11 of the controller. Any ideas as to what we can do specifically??
any response would be much appreciated.
Unread 10-02-2009, 13:44
Specifically, you can help us figure out what you're referring to. I'd usually consider the cRIO and "the controller" to be the same thing.
There are three or four things that you need to keep updated properly. First is the LabVIEW environment on your programming computer (that should be Update 3.0a). Second is the cRIO image (v11), which gets installed along with the LabVIEW update. Third is the Driver Station firmware (2009-01-22c1). I'm not keeping track of the the WindRiver libraries myself, since I'm focusing on LabVIEW, but you need to keep it up-to-date as well if you intend to use C++ for programming.
Unread 10-02-2009, 22:11
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
When re-imaging with 3.0a and ver 11, I keep getting an 'error 56'. Any idea of what that is?
It had been running well up to this point.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 10-02-2009, 23:00
56 is a timeout on a network operation. Simplify the network connection and see if that helps.
To get quick explanation of errors, you can use Help>>Explain Error, or you can usually right click on an error control and Explain...
Greg McKaskle
Unread 10-02-2009, 23:03
Jon236's Avatar
AKA: Jon Mittelman
Greg McKaskle
All I had was a crossover cable from the laptop to the cRio
Jon Mittelman
Unread 10-02-2009, 23:55
Try running through the DS, using it as a switch. e.g., PC to DS to cRIO wired directly. Sometimes using a switch as an intermediary smooths communications.
Unread 11-02-2009, 09:34
Make sure to disable firewalls, and perhaps try on a different computer.
Greg McKaskle
Unread 11-02-2009, 10:00
One thing that might point to is a mismatch in the network addressing. Make sure your computer's IP address and mask are what they should be (10.2.36.6/255.255.255.0), and that the cRIO Imaging Tool is being told the correct team number (236). You could also get away with using 255.0.0.0 for the network mask.
WindRiver Errors ExarKun666 C/C++ 7 04-03-2009 20:32
Makefile Errors neutrino15 Programming 1 29-01-2008 15:45
LINKING ERRORS!!! AHepperla Programming 4 19-01-2008 10:00
CAMERA ERRORS!!!!!!!!!!!! Hershey Programming 0 21-01-2005 18:59
