Go to Post Making even just one person feel safe and included in FIRST is how we know that we have succeeded. - Mr_Moko [more]
Unread 10-02-2009, 22:15
Comatose Comatose is offline
AKA: Lead Student Programmer
FRC #0135 (Penn Robotics)
Comatose is an unknown quantity at this point
Programming Camera that uses USB
Is there a way to set the camera by USB if you use a different camera? If so, how?
Thanks,
Comatose
Sleep? What good is a sleep.vi going to do? *Collapse*
Unread 10-02-2009, 22:17
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Programming Camera that uses USB
Thanks,
Comatose
There is no USB on the cRIO
___________________
- Tennyson, Ulysses
Unread 11-02-2009, 20:28
There are converters from USB to Ethernet, so it would be a problem for programming. Can you set up a USB one if it was connected through a converter?
Thanks,
Comatose
Unread 11-02-2009, 20:34
See <R67>
Unread 11-02-2009, 21:19
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
If you were to have an off board computer,that did not violate any COTS rules, and you hooked said computer to the cRio using the serial port or some other port. then yes you could have a USB camera . .you would also have to program every thing to get the camera to work with the off board computer, how it would communicate, then what it would do after that. So yes it is possible.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 12-02-2009, 01:14
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
This is the way you'd have to do it, but you're out of luck for the serial port. Digital I/O, Analog In, I2C only.
FRC 766, 2015-, Mentor
Anyone have any leads on the steering wheel controller that uses a 15 pin connector? waialua359 Control System 20 30-01-2008 12:58
away around the USB chicklet for using USB Controllers Stobei Programming 2 26-01-2008 14:27
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
Creative uses for the USB Port Zero-Bee Control System 53 23-01-2007 18:01
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
