Go to Post it doesn't matter so much why i joined [FIRST], but that i stayed :D - sure_smile [more]
Unread 11-02-2009, 00:27
sbrumund sbrumund is offline
FRC #2115 (M cubed)
sbrumund is an unknown quantity at this point
Coupler for 8mm CMI motor
Does anyone make a coupler that will go from the 8mm shaft of the CMI motor to a standard 0.50 shaft with keyways?
We want to drive our ball thrower directly off of the CMI motor but cannot find a coupler to go from the 8mm motor shaft to the 0.50 wheel hub.
spare denso motor coupler AnonymousPencil Motors 2 09-02-2009 13:09
Coupler for Denso Motor nlknauss General Forum 1 05-02-2007 17:20
CIM motor shaft Coupler Epot86 Motors 13 14-01-2006 22:05
Securing Drill Motor Coupler Ralph Lambert Motors 17 08-02-2003 01:54
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
