Go to Post The weight sounds about right, too. If you need more than 65 pounds for your manipulator, then the drivetrain isn't the part you should be redesigning... - s_forbes [more]
Unread 11-02-2009, 08:02
Re: Question about DS showing battery voltage
Your second configuration is not only legal, it is the only correct way to do it.
Question about battery placement itsme Electrical 7 11-02-2008 16:18
Question about battery placement itsme Technical Discussion 7 11-02-2008 16:18
[OCCRA]: Question about the battery wbhsAndy OCCRA Q&A 1 24-10-2005 20:11
Battery voltage Josh Siegel Programming 5 22-12-2003 10:15
Battery Voltage Neal Probert Programming 3 09-01-2003 10:18
