Go to Post We want your $0.02!!!! (and for that matter, if anyone can loan me $1.49 for a few donuts....) - dlavery [more]
Unread 10-02-2009, 23:13
Drake Hunter's Avatar
Drake Hunter Drake Hunter is offline
Fighting Rednecks
FRC #2883 (F.R.E.D)
Drake Hunter is an unknown quantity at this point
WE GOT A PROBLEM!!!!
We recently rewired our robot and when i went to turn the robot on and everything started moving so im not sure what is going on....not sure if it has to do with the cRIO but i've checked the wiring and cant find anything obvious i did wrong....any suggestions would be greatly appreciated
Unread 10-02-2009, 23:15
Re: WE GOT A PROBLEM!!!!
Everything started moving?
Is your joystick trimmed?
Please provide more information about your specific problem so we can help.
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
Are you programmed for jaguars and using victors?
Unread 10-02-2009, 23:27
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Pictures are worth 1,000 words. I don't know where to start helping you.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 10-02-2009, 23:30
zivo123 zivo123 is offline
FRC #1690 (The Asnswer)
zivo123 is on a distinguished road
plug out the joysticks and turn on again that can give us the first clue for what the problem is..
Ziv Oriol
Email - ziv_o123@walla.co.il
Our first game in the Israel regional:
http://www.youtube.com/watch?v=a_92wGPhWig
Unread 10-02-2009, 23:43
Fighting Rednecks
FRC #2883 (F.R.E.D)
The thing is i dont have the driver station plugged in and it still moves
Unread 10-02-2009, 23:59
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Autonomous taking over?
DUDE! Check that you don't have the wires in the jaguars/victors inverted...
Unread 11-02-2009, 00:11
Fighting Rednecks
FRC #2883 (F.R.E.D)
I think that might have been our problem....thanks
Unread 11-02-2009, 01:43
Fighting Rednecks
FRC #2883 (F.R.E.D)
we switched them around and it still doesn't work....do you think we could have fried the jags?
Unread 11-02-2009, 01:59
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
If there is no driver station plugged in and you are still seeing this behavior it is likely that something is wired incorrectly. With no DS the cRIO should have the outputs disabled. To verify this the small green LED to the right of the RSL connector should be on a fast blink (200ms on / 200ms off).
If this is the case you either have a hardware failure or a wiring issue.
The PWM cable should be connected to the Jaguar with the Black wire on the "inside" (the side where the other ports are located). The other end of the cable should be connected to a PWM header on the Digital Sidecar with the black wire on the "outside" (the side away from the adjacent 2 pin headers).
The Jaguar should have V+ connected to a red terminal on the Power Distribution board with an appropriate breaker installed and V- connected to the adjacent black terminal. M+ and M- should be wired to one terminal of the motor each.
Unread 11-02-2009, 10:02
AKA: Yamil Asusta
I know because my team did the same thing...
Just open them and fix them.
It should have an open circuit or something like that. I didn't fix them myself so I'm not completely sure.
Unread 11-02-2009, 10:09
Electrical Engineer
Rookie Year: 1995
If you didn't before, you have now...
Jaguars are not protected on the input voltage terminals from reverse wiring. Wiring the input in reverse polarity will almost certainly destroy the device.
Mike
Mike Betts
As easy as 355/113...
Unread 11-02-2009, 10:20
AKA: Yamil Asusta
Jaguars are not easy to fry.
I thought the same thing here and people said I was doomed and we fixed them
Just open it and give it to somebody that knows about open circuits.
Unread 11-02-2009, 10:58
A representative from Luminary Micro said do not reverse the wiring. They are not protected by anything other the circuit breakers.
Unread 11-02-2009, 11:16
Electrical Engineer
Rookie Year: 1995
I'm sorry but that is not allowed as per the GDC: http://forums.usfirst.org/showthread.php?p=26610
Regards,
Mike
Mike Betts
Got Gyro? PhilBot Control System 18 27-01-2007 14:57
Got it working now theres another problem! cdennisxlx2 Programming 11 25-03-2006 21:58
I got GAME! Goober!!! Games/Trivia 3 07-02-2005 21:43
got Countdown? archiver 2001 3 24-06-2002 03:40
