Go to Post I don't even care if it doesn't work as well as they would like. YOU MADE IT. You may never use it, but you made it. AWESOME. Every year there has been 1 team (sometimes 2) that has done something that really stood out. This year 1 team has done 2 things that stand out. Thanks guys. - rees2001 [more]
Unread 05-02-2009, 18:39
HarryScheiner HarryScheiner is offline
Mentor for Team 1358
FRC #1358 (MacArthur Generals)
HarryScheiner is an unknown quantity at this point
How do I load the default code?
Hi, I'm trying to set up Wind River with the default code to get at least something on the flash memory of the cRIO. I've set up a project with the SimpleTemplate, but from what I can see, the project only includes .h files, and MyRobot.cpp. Shouldn't there be .cpp files for each .h file? I can see no declarations for any of the functions in the .h files anywhere in the project, and I searched for ".cpp" in the WindRiver directory and could not find anything. However, I downloaded the source code (WPILibRC0.1718SourceCode.zip) from http://first.wpi.edu/FRC/frcupdates.html , but I can't figure out what directory it has to go in in order for this to work.
Any help would be greatly appreciated. Thank you.
EDIT: I forgot to mention, the default code from the cRIO imaging tool works fine, but it does not stay in memory after a reboot.
Unread 05-02-2009, 21:58
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: How do I load the default code?
There are no .cpp files because they are pre-compiled. Just build the default template, and download it to your robot. The file to load is found under preferences->first downloader
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 05-02-2009, 22:24
I tried that, but when I load the code the robot does not move.
Unread 06-02-2009, 17:52
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
did you go to File>New>Example:vxWorks Download... :Next:FRC Simple Robot Template:Finish?
also make sure you enable the robot
Edit: enable by the switch you attach on the side of the DS
Watchdog.Kill();
Unread 06-02-2009, 18:51
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
HarryScheiner,
1)Did you make sure to Undeploy (Under the same FIRST menu bar entry as Download) before downloading the SimpleTemplate?
2)After downloading, did you reset the robot?
3)Have you connected the cRIO's serial port to your PC via a null-modem connection? Is VxWorks throwing up any error messages to the console as it boots?
Which badges can you claim?
Unread 09-02-2009, 17:40
Originally Posted by Redneck View Post
HarryScheiner,
1) Yes
2) Yes
3) Could you explain this? I'm not sure I understand.
Unread 10-02-2009, 16:46
Redneck's Avatar
Hacker Hick
FRC #0599 (Robodox)
What I mean is, have you done the following:
-Flipped the DIP switch on the cRIO that says "Console"
-Connected the 9-pin serial port on the cRIO to your computer (either a serial or USB port, depending on what you have available) with a null-modem cable
-Opened a terminal in Workbench (from the menubar Window -> Show view -> Terminal) or connected via some other program like HyperTerminal or PuTTY. Regardless of what you use, the settings should be:
connection type - serial
9600 baud,
8 data bits,
1 stop bit,
no parity,
no flow control
-Watched the cRIO's boot messages on the terminal to see if it's outputting any errors
Unread 11-02-2009, 11:52
Thank you. I managed to get it working, it turned out to be the simple mistake of not having the latest cRIO Imaging Tool. Guess I glanced over that one when I was updating
The Default Code robocata Programming 1 29-01-2006 17:59
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
Can't Compile the Default Code pressurex1 Programming 4 25-01-2004 20:26
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
