Go to Post It's not fair. it's not right, but stuff like this happens. If you don't get picked for finals tomorrow, get in those stands and cheer for those who did. Remember, this is FIRST. - wilsonmw04 [more]
Unread 11-02-2009, 11:56
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Re: changing code after it's set to run at startup
So, as I understand it, if we re-deploy updated code, it will automatically replace the current executable that's residing witin the cRIO? As long as it's set to Run At Startup?
BTW: We did watch all the LVMastery videos, 5-12 (I believe Mr. Zimmer is on 12 now anyways...). We got so much out of them, and thought they were so good, that we sent the hyperlink to our Regional Director here in Pittsburgh, which she then sent to the other Pittsburgh-based teams.
Unread 11-02-2009, 12:04
Electrical Engineer
Rookie Year: 1995
That is my understanding as well. You have to deploy as Run at Startup. If you just Run, it will not be permanent.
BTW, Mr. Zimmer is up to #16... Good stuff!
Best of luck,
Mike
Mike Betts
As easy as 355/113...
Unread 11-02-2009, 19:36
Brdn666's Avatar
Brdn666 Brdn666 is offline
AKA: Brandon
FRC #2604 (Metal & Soul)
Brdn666 is an unknown quantity at this point
Send a message via Yahoo to Brdn666
All you have to do is re-build the code to do the changes. It's not worth building the code if you make changes every 20 mins.
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
KOP Gyro seems to run-on after turn stops PhilBot Control System 8 05-03-2007 12:43
How to set up and run a FF League properly. Alex Cormier Fantasy FIRST 4 27-02-2006 17:18
Changing Code Formatting in MPLAB!!! Yeah!!! Astronouth7303 Programming 1 09-03-2004 18:07
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
