Go to Post ..this is the first robot we've built that succeeded at everything we wanted it to. It was simple. It was low maintenance. It scored effectively. It had an autonomous that worked. Its look caught attention. And it was finished on schedule. - Donut [more]
Unread 10-02-2009, 01:22
jmarsh24 jmarsh24 is offline
FRC #2085
jmarsh24 will become famous soon enough
Controller board lighting system
My team are trying to find cathode lights to put inside our controller board and we are trying to find lights that would be able to be powered by the driver station. Does anyone have any ideas on places to buy lights?
Unread 10-02-2009, 02:35
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: Controller board lighting system
I have had good luck with both of these:
http://www.frozencpu.com/
-John
Unread 10-02-2009, 10:23
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
One thing that you want to be careful of is that you don't overtax your driver station's 5v system. I don't remember how much amperage cathodes pull off the top of my head, but I believe it's significant. We have a separate power supply for cathodes, and it works great(plus it enables you to run them even when you're not hooked to competition or wall power)
Get yer robot source code here!
Unread 10-02-2009, 11:03
pitzoid's Avatar
pitzoid pitzoid is offline
AKA: BOB
no team (4FX Design)
pitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of lightpitzoid is a glorious beacon of light
I appreciate you guys want to have cool looking stuff when you're on the stage. I like to dress stuff up. I just ask that if at all possible, please use a seperate battery or similar to power lights or non-essential items on your drivers station. Make sure your laptops you take to the drivers station are charged up too, there isn't anywhere to plug them in at the drivers station.
Here's a cool place to get cheaper LED and computer case lights.
Deal Extreme
BotBash BOB Pitzer
Harvest CROO Robotics and 4FX Design
Unread 10-02-2009, 12:25
FRC #2085
what are you guys using as an external power source? We have a box with nothing in it except lights, so having a robot battery in it, isnt the best option...
Unread 10-02-2009, 12:47
aj55369 aj55369 is offline
Electrical / Electronics
FRC #2845 (OBots)
aj55369 is an unknown quantity at this point
For my team, I purchased LED strips and Cold Cathode lights, both of which run on 12v. LEDs don't draw very much power, although the CCFL's do add up. I would reccommend keeping the number of CCFLs to a minimum, and also know that if you try to lengthen the wires from the transformers to the lights - you will lose brightness significantly.
I order my LEDs from http://www.superbrightleds.com because they are based in the USA and ship darn fast via USPS. Prices are more than dealextreme.com, but from my experience, most of what dealextreme sells is shipped from China - I prefer to buy USA made.
Best of luck,
AJ
Unread 10-02-2009, 13:03
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
We used some green cathodes from oznium.com last year. I ran then off of a 9.6v vex transmitter battery and they were plenty bright.
-Dustin Benedict
Unread 10-02-2009, 16:48
Blair Frank's Avatar
Blair Frank Blair Frank is offline
Writer and Alumnus
FRC #0852 (Athenian Robotics Collective)
Blair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the rough
From what I've read, power sources separate from the DS are not allowed in this year's competition. Correct me if I'm wrong, but running cathodes off of a vex battery would appear to be against the rules.
Proud alumnus of Team 852, the Athenian Robotics Collective.
Pneumatics in a nutshell: Put together an elaborate series of pipes, canisters, cylinders, valves and hoses; then fill that system with highly pressurized air, and hope that it doesn't blow up in your face.
Unread 10-02-2009, 19:03
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
that's what i thought...
-Z
[center]
Unread 10-02-2009, 19:16
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Can you point to a particular rule that would prohibit that?
There are several rules the prohibit items powered by external sources from being connected to particular ports on the Driver Station. Perhaps you are confusing items covered by those rules with all elements of the operators console?
-dave
Unread 10-02-2009, 21:11
I was thinking the same thing, but I didn't have time to hunt up the rules, so I didn't look it up at the time. I have now done so.
The one (and only one) rule I can find, the one for non-functional decorations, doesn't apply here, due to the fact that it's kind of hard to run the operator's station or anything attached to it from a robot's battery from a minimum of 9 feet, moving away, with 5 other robots getting in the way, and without having a cable to do it with.
However, I would urge caution in the use of lights on a control board. Do your best to avoid creating a safety hazard. Sure, it's cool, but if safety is compromised, I'd much rather you not do it. There are a number of ways to mitigate this, including "frosted" polycarb/acrylic or polarization, that would turn a questionable light into an unquestionably legal one. You can also create some really cool effects this way.
Unread 11-02-2009, 12:02
FRC #2085
How many LED lights could we hook up to the controller board if they draw 2 miliamps, without sacrificing crucial power to the rest of the things its doing?
Unread 18-02-2009, 00:12
BlackBird11891's Avatar
BlackBird11891 BlackBird11891 is offline
We Rise Above Our Challenges
AKA: Chad Krivanec
FRC #1927 (Team Tempest)
BlackBird11891 is on a distinguished road
what we did is we used the cathodes that were used off the light off "Rack & Roll" we also have a fan on our board that blows under the laptop... what we did was put a "female connector" hard mounted on our board and ran the DS fan and lights off of the power cord cumming from the transformer that is part of the kit it ran for an hour and a half one time and was fine the cord, which should be the same as the one at competition, worked great..... no need for another power supply
Unread 18-02-2009, 04:14
mcf747 mcf747 is offline
AKA: Matthew Forman
FRC #0190 (Team 190)
mcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud of
I may be wrong but per R83
<R83> Nothing can be connected to the power connector on the Driver Station during a MATCH.
I think the power will be coming through the D-sub and not the power cord that you guys have been using.
Im not sure but watch out for this.
Matthew
Mortorq 1515
Unread 18-02-2009, 04:54
I'm with Matthew. Power during matches doesn't come through the power supply. It comes through the competition port. Try another solution.
USB to controller board chicklet ExarKun666 Control System 3 03-04-2008 06:17
Autonomous Controller Board Switch merybar Technical Discussion 9 25-03-2008 08:04
Our Controller Board LordFrz Robot Showcase 12 08-02-2008 14:31
Autonomous Controller Board Switch merybar General Forum 2 27-01-2008 12:54
Cool Controller Board jacobevelyn Control System 3 26-01-2008 13:13
