Go to Post I want to understand the physics. - Molten [more]
Unread 11-02-2009, 12:24
Re: Trouble using Spike Relay
The relay outputs are correct for connecting to Spike relays.
There are LEDs adjacent to the relay pins on the Digital Sidecar. When you tell the door relay (#4) to turn on forward, its associated green LED should light. Does it?
Are the Digital Sidecar's 12v and 5v power LEDs lit? Is the RSL on steady?
Relay (Spike) elbuo Electrical 2 09-02-2009 20:36
Spike relay question Zack Briggs Electrical 17 19-02-2008 14:48
using SPIKE relay module with Fisher Price motors 1574aviad Motors 4 27-01-2005 01:49
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
