Go to Post No, I've never done 3D programming before, but I'm young and naive, so I still think I can do it. ;) - Ryan M. [more]
Unread 03-02-2009, 18:51
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Question Bumper weight
Does anyone know of a way to increase the weight of our bumpers? For example, could we put steel plate inside the wood backing? Thanks for your help.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 03-02-2009, 18:56
Electrical Engineer
Rookie Year: 1995
Re: Bumper weight
Joe,
No you can not do that.
However, the bumper design allows for optional angle along the back edge of the plywood. It does not say if the angle is aluminum or steel or what the thickness is.
This should give you ample engineering margin to insure that your bumpers are the maximum allowed weight (18 pounds).
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 03-02-2009, 19:05
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumper weight
At the risk of being labeled a self-proclaimed rules expert ...
I don't see anything in the rules that specifically denies this. But in the past the Q&A has said that the only materials that can be used in the bumpers are the 4 elements mentioned in the rules: Plywood backer board, Pool noodles, Cloth covering, Angle clamping brackets. Plus associated hardware needed to put them together and attach them to the robot.
Remember, you have a maximum 18 pound weight limit for your bumpers.
Ask the Q&A using your official login found in your TIMS.
(since 2004)
Unread 03-02-2009, 19:08
jblay's Avatar
AKA: Joe Blay
Re: Bumper weight
Thanks for the information, Mike, but where did you find that?
Unread 03-02-2009, 19:21
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Bumper weight
Section 8 Robot Rules - please tell me you've heard about the rules docs.
Russ Beavis
Unread 03-02-2009, 19:29
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Re: Bumper weight
Rule R08 Sec. G and H specify that you may use a multi-part attachment system. That attachment design is left up to the team as long as it is robust enough to withstand rigorous play
Unread 03-02-2009, 20:30
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Bumper weight
Simple solution...use a denser wood. Locate some true baltic birch plywood. That should be a good bit heavier than generic home-depot garbage plywood and a whole lot stronger to boot.
Mentor 2415
Unread 04-02-2009, 15:56
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Re: Bumper weight
Denser wood is a good way to get more weight. It's so much heavier than standard plywood that we chose not to use it this year because we got into bumper weight trouble one year when we used iron angle on our front bumper. It passed inspection after we lightened up a bit.
Unread 11-02-2009, 00:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Bumper weight
Weighed our bumpers tonight...8 lbs....I guess we need to find 10 pounds of something legal to add to them! We probably have enough Baltic Birch to add a couple pounds, and we could add some 1/2" x 1/8" aluminum angle...
Unread 11-02-2009, 02:14
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: Bumper weight
Wow,
that is actually really light.
Ours came in at 12 pounds and we thought our's was light.
Its too bad we couldnt put some of our 8lbs over, from our robot to the bumpers.
Unread 11-02-2009, 02:31
AdamHeard's Avatar
Lead Mentor
Re: Bumper weight
You can also use steel angle, much easier to get 10lbs out of that.
1/2" x 1/8" 6061 is around .1 if the numbers in my head are correct.
you probably want something more like 3/4" x 1/8" steel, that's about .6 lbs a foot.
Unread 11-02-2009, 02:44
dtengineering's Avatar
AKA: Jason Brett
Re: Bumper weight
There is no rule regarding the humidity content of the plywood... soak it in water for a while...
Mmm... mouldy bumpers!
Jason
Unread 11-02-2009, 03:33
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Re: Bumper weight
Jason
We were joking around earlier this year about taking it a step further. Why soak the plywood when you can soak the whole bumper, pool noodle and all? We would have big buckets of water in our pit, and reattach the soaked bumpers before each match. This idea was later discounted when we realized that our technique would be easily recognized when we hit another robot and water splashes all over.
Unread 11-02-2009, 09:07
Re: Bumper weight
Petrified plywood?
Unread 11-02-2009, 14:19
jgraber jgraber is offline
jgraber is just really nicejgraber is just really nicejgraber is just really nicejgraber is just really nice
Re: Bumper weight
Originally Posted by Russ Beavis View Post
Petrified plywood?
My rookie parsing of the Bumper rules and Q&A is that anything inside the bumper perimeter that you can call a "bumper attachment bracket" that is permanently attached to the bumper is fair game. An 8 lb bumper perimeter with 10 lbs of bolts to hold it on, a plywood subfloor across your whole robot that bolts upward to the frame, etc.
This could have been designed into the frame to provide a lot of frame strength, for those teams with 3lb frames.
10 lbs of bolts, where each bolt costs less than $1 would not count against the cost budget too.
Per recent Q&A, bumpers need to meet $3500 budget rule and shipdate rule.
Bumper bracket and weight considerations ajlapp General Forum 26 30-09-2008 15:36
Making Bumper Weight? Ian Curtis General Forum 28 17-02-2008 09:34
bumper weight chippermonky Technical Discussion 10 09-02-2007 14:42
Weight? Estmate weight? Arkorobotics General Forum 21 29-01-2007 17:34
Wait...weight...weight!!!! Greg Perkins General Forum 3 22-02-2006 07:42
