Go to Post P.S. could we get Kanagasabapathy added to the spell check? or will it not handle words that big? :) - Holtzman [more]
Unread 11-02-2009, 08:57
nofar#1943 nofar#1943 is offline
FRC #1943
nofar#1943 is an unknown quantity at this point
Autonomous error
I wasn't sure where to post this, it seemed like the most relevant forum.
Lately we updated the cRIO and LabView, and now our autonomous mode works only once, after I switch to Teleop if I switch back to Auto it writes on the driver station disabled and not letting the Autonomous run.
Is it because of the update?
How do I fix it?
Unread 11-02-2009, 10:34
Re: Autonomous error
We've run autonomous multiple times since the update.
There are many things you can do in your code to cause this kind of problem. It would be helpful if you posted your project.
Unread 11-02-2009, 14:20
Joshua Moyerman Joshua Moyerman is offline
FRC #2797 (Knight and Nerdy)
Joshua Moyerman is an unknown quantity at this point
The Driver station will not allow autonomous code to be run if it has already been booted as Tele-Op. The Driver Station in order to run Autonomous will HAVE to be started up with the switch set to Auto. Then, you can switch to tele-op.
Happy Testing!
Unread 11-02-2009, 15:58
Happy Testing!
That is only true of the OTB versions of the firmware. Make sure you are using LabVIEW update 3.0a and cRIO image v11.
Unread 22-02-2009, 01:33
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
If I updated Labview and the cRio as you said, I won't have to do what Joshua said? 'cause we had several issues with Autonomous working and not working after updating everything (not really sure that we tested autonomous before that).
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 22-02-2009, 11:01
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
If you're using the most recent version, it shouldn't have this problem
I would say check your AutonomousInit function(or the thing above your autonomous while loop if you're using SimpleRobot). Make sure that you're intializing all the variables that you use in autonomous every time it is initialized.
Get yer robot source code here!
LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi RMS11 Programming 8 08-12-2008 18:20
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
