Go to Post They see us come into school looking like zombies, and they know that some people start smelling like chain lube and such...but for the most part, they don't realize that for a lot of us, there is a deep commitment to our team that we do a very large amount of work for that team. - JakeGallagher [more]
Unread 11-02-2009, 14:57
Red Mage's Avatar
Red Mage Red Mage is offline
Owner of Holistic Omniscience
FRC #1546 (Chaos Inc)
Red Mage is on a distinguished road
Send a message via AIM to Red Mage
Half of pneumatics doesn't work
Okay, half the solenoids on our robot don't work. The compressor works and two out of four solenoids work. The wiring is identical for all solenoids and they are all coded the same. So when the non-functional solenoids should fire the corresponding lights on the Solenoid Module turn on but the solenoids don't change. When we hook them up to Spike Relays they work. Help would be appreciated. I'm willing to pay in hot dogs.
Don't Blink. Blink and you're dead. Don't turn your back. Don't look away. And don't Blink. Good Luck.
Unread 11-02-2009, 15:12
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Half of pneumatics doesn't work
What solenoids are you using? There was only on in the KOP....are the others identical? source?
Unread 11-02-2009, 15:18
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Keep in mind that the Solenoid Breakout is only a high-side driver (ie 12V across the leads or open) whereas the Spike is a full H-bridge (+12, open or -12V).
Maybe your valve is wired backwards and there is a diode that prevents current flow?
Russ
Unread 11-02-2009, 16:13
Lord_Jeremy's Avatar
Lord_Jeremy Lord_Jeremy is offline
Lord_Jeremy the Procrastinator
AKA: Jeremy Agostino
FRC #1546 (Chaos Inc.)
Team Role: Electrical
Lord_Jeremy is an unknown quantity at this point
Send a message via ICQ to Lord_Jeremy Send a message via AIM to Lord_Jeremy Send a message via MSN to Lord_Jeremy Send a message via Yahoo to Lord_Jeremy
We are using the double-solenoid valves that were included in the kit of parts in previous years. (I believe they are made by SMC.) We are extremely sure that the valves are not wired backwards because we switched the connections for each solenoid across the various outputs on the Solenoid Breakout and only some of the outputs worked consistently. The other outputs appeared to never work at all, although their corresponding lights on the Solenoid Module would illuminate. We are toying with the idea that the Solenoid Module and/or Breakout is damaged. At this point we probably don't have time to get another Solenoid Breakout and Module so we moved the four non-working solenoid groups onto spike relays and are doing them the "old school" way. Is there a way to test out Solenoid Module and Breakout system? If one of these components are damaged, how can we get replacements and are they covered under any warranty? Are there any rules or regulations that would disallow the use of spike relays with the SMC double-solenoid pneumatics valves?
Compiling...
Compiling...
Unread 11-02-2009, 16:24
Do you have a schematic for your wiring? I'm not positive that you've properly split the 2 valves' windings across a pair of Solenoid Breakout outputs. When using a Spike, the winding pairs are spliced together and driven such that A or B or neither are energized and there are diodes in the windings that prevent them being energized simultaneously. When using the Solenoid Breakout, you'll need to wire A to one output and B to another and make sure that the polarity is correct (else the diode will not keep one of them from being energized).
Russ
Unread 11-02-2009, 16:29
Our wiring is such that Solenoid Breakout port 1 SIG goes to the positive terminal of side A of the valve and port 1 (-) goes to the negative terminal of side A of the valve. Port 2 SIG goes to the positive terminal of side B of the valve and port 2 (-) goes to the negative terminal of side B of the valve. This is repeated for the three additional valves of the same type.
Compiling...
Compiling...
Unread 11-02-2009, 16:50
You might want to swap the connections for the B windings. It's too coincidental that half of the windings aren't being energized but the NI 9472 LEDs are lighting up.
Russ
Unread 11-02-2009, 16:58
It wasn't a matter of only the B lines not functioning. Only outputs 2, 3, 6, and 8 appear to be functioning. What we've done now is wired two of the valves on those working ports and put the other two on 2 pairs of spike relays.
Compiling...
Compiling...
Unread 11-02-2009, 17:20
Can you verify that the lights on the cRIO module are lighting up as you would expect? Can you verify that the voltage across the valves are what you would expect?
Can you post your code?
Thanks
Unread 11-02-2009, 17:58
krankin krankin is offline
FRC #1164 (Project NEO)
krankin is an unknown quantity at this point
The solenoids from past years have come configured for 24V and then FIRST sends us the part to change it to 12 volts. I am not certain what voltage the cRIO puts out but you might want to check to be certain that your solenoids are configured to the correct voltage. The voltage that the solenoid uses is written on the side of the part that you plug the wires into.
Unread 11-02-2009, 19:04
I noticed that only 1 of your nonfunctional valves is a "B" half. My hot dog is still on the diodes that are in the double-acting solenoid.
Did you try moving the 1, 4, 5 and 7 "valves" to the 2, 3, 6 and 8 positions?
The NI modules are almost bulletproof and the Solenoid Breakout is stupid simple. I'd be really surprised if the LEDs for the 1, 4, 5 and 7 positions lit but you didn't get voltage to the valve.
Russ
Unread 11-02-2009, 20:27
Red Mage's Avatar
Whelp, half of our system is running on Spike relays and the other half is on solenoids. This is the weirdest setup I've seen but whateves. The important part is that it works. Thanks to everyone who posted.
Unread 12-02-2009, 09:52
If you want me to take a look I can come by Friday afternoon and bring a solenoid module with me.
Festo Solenoid Doesn't Work frank.pendzich Pneumatics 20 11-02-2009 20:33
LCD Doesn't work :( magical hands Programming 6 08-03-2007 20:37
My Chicklet doesn't work r_is_for_ROSER Control System 6 26-02-2007 11:20
Arrrrrrrg... PM alert doesn't work DanL CD Forum Support 9 08-05-2003 14:32
sensor doesn't work PBoss Programming 7 29-01-2003 18:39
