Go to Post Does this need a "Do not try this at home" stamp? - sanddrag [more]
Unread 11-02-2009, 17:10
nyindojin nyindojin is offline
FRC #3059
nyindojin is an unknown quantity at this point
Question how to hook up the eletrical wiring
thank you for you help so far, we got our parts.... and we were able to assemble and test the pneumatic system but how do we connect the wiring to program the pneumatic system, the compressor is conneted to the black circuit breaker, which is then connected to the digital sidecar, what do we do do next to the regulator and the festo?
Unread 11-02-2009, 18:15
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: how to hook up the eletrical wiring
I'm assuming you mean the compressor is connected to the Spike, which happens a black box. The breakers can also be described as "black boxes", though, so this is something to confirm.
The regulator doesn't need to be connected to any electronics. The pressure switch, however, should be connected to one of your digital inputs. When the switch inside opens, it means the system has reached maximum pressure.
The Festo should be connected to the pneumatics bumper. Unlike past years, it's not necessary to drive solenoids from Spikes; they can be hooked directly up to the bumper.
Unread 12-02-2009, 11:43
FRC #3059
Question Re: how to hook up the eletrical wiring
Thank you for your help, here is what we have done so for....
Yes it is connected to the spike relay, then pressure switch is connected to the dio, and festo is connected to the solenoid, you stated that you do not have to connect the spike, but if the spike is not connected to the digital side car the compressor does not turn on. Once again thank you for your help.
How to hook up the tubing with the brass fittings nyindojin Pneumatics 1 02-02-2009 16:47
How to hook up a Police light on the Robot?? xur2007 Technical Discussion 4 13-11-2006 18:27
How do you hook up the camera? SpeakerSilenced Programming 18 16-02-2005 15:00
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
