Go to Post At this time of the season, there is only one response: BAAAAAAAAA-humbug! - dlavery [more]
Unread 10-02-2009, 16:42
Wicked Wicked is offline
FRC #0354 (G-House Pirates)
Wicked is an unknown quantity at this point
Encoder Motor Control
Me and my team have a little problem. We want the encoder to make the motor stop moving at a certain position. We tried using the encoder example VI to do this, but nothing happened. We are using the encoders included in the kit (optical). Any help would be greatly appreciated.
Unread 11-02-2009, 17:05
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: Encoder Motor Control
Can you post the pertinent code that is not workin? Is the encoder working properly in your project?
Unread 11-02-2009, 17:41
Hold on, let me rephrase this. We used the encoder example VI to receive readings from the encoder, that's working fine. Now we want to use those readings to make the motor stop at a certain point.
Unread 11-02-2009, 18:21
OK, now I understand what you want (I think). So I presume you want to make a motor (let's assume a Victor) move in a single direction until the encoder count reaches a certain value (i.e. setpoint).
If you look at the included Motor Control Example, which is available from the Examples on the Getting Started window when LabVIEW starts up (or from View->Getting Started Window... in the menubar), then you can see how to tell a motor to go to a set speed.
In your case, you probably want it to be driven at a fixed speed until the encoder hits your setpoint. So instead of using a control like the Motor Speed (-1 to 1) in the Motor Control Example, you could use a case structure or Select function.
The encoder value could be wired as shown in the picture to set the motor speed.
Can any one help us with programing the encoder to control the motor by ticks? Must Be Drama NI LabVIEW 4 09-02-2009 20:54
Optical encoder for denso window motor? jaredtkatz Motors 0 04-02-2009 16:10
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
PID control loop/Encoder question Zee Programming 18 30-01-2004 23:14
Motor Control archiver 2000 1 23-06-2002 23:01
