Go to Post P.S. No matter what happens a build season, you will always have memories. - Briansmithtown [more]
Unread 11-02-2009, 18:34
nevereverregret's Avatar
nevereverregret nevereverregret is offline
AKA: sammy
FRC #2869 (One Small Step)
Team Role: Student
nevereverregret will become famous soon enough
Send a message via AIM to nevereverregret
Exclamation No pneumatics work help
We have last years solinod valves hooked up and they work manualy but when wired and connected to the program they wont move but retract when the system is pressureized. The lights go on on both the solinod and the breaker....
PLEASE HELP WITH WIREING!!!!! THANK YOU SOOOO MUCH
"How do you join.
You show up.
How do you get responsibility.
You take responsibility."
Unread 11-02-2009, 18:42
Pumagrif's Avatar
Pumagrif Pumagrif is offline
Crazy 204 Mentor
AKA: Geoff
FRC #0204 (Eastern Robotic Vikings)
Pumagrif is an unknown quantity at this point
Re: No pneumatics work help
Make sure the Solinod break out is wired correctly to the solinod valve. If that doesnt help double check your connections and still nothing contact me ill help as much as I can
For a successful technology, reality must take precedence over public relations, for Nature cannot be fooled.
Unread 11-02-2009, 20:14
AKA: sammy
Team Role: Student
How would you wire it exactly???? lol thanks for the help!!!
"How do you join.
You show up.
Unread 12-02-2009, 08:14
Pumagrif's Avatar
Crazy 204 Mentor
AKA: Geoff
On the smc valve where the wire pins are there is a polarity indication on the side show positive or negative. You will hook those pins to wires which need to be plugged in to another set of pins on the solenoid break out on the cRIO. If you like somr pictures of what I'm talking about let me know.
Half of pneumatics doesn't work Red Mage Pneumatics 12 12-02-2009 09:52
pneumatics help!!!!!!! qwertyzzzzzzzzz Pneumatics 1 05-02-2008 09:09
Pneumatics Help Zultraranger Pneumatics 9 26-01-2008 15:05
Pneumatics Help Transformers Technical Discussion 8 11-01-2007 19:56
Pneumatics Help! archiver 2001 2 24-06-2002 00:45
