Go to Post We started FIRST to achieve a common goal and not only will we leave with more knowledge and wisdom, we will leave as friends and thats what really counts if you ask me. :cool: - Hick18 [more]
Unread 30-12-2008, 21:06
ravena ravena is offline
FRC #1444 (Lightning Lancers)
ravena is an unknown quantity at this point
Problems reimaging cRIO
I've made it up to the point where I need to reimage the cRIO. I have the updated code on my laptop. I have the orange cross over cable directly from my laptop to the cRIO port 1. (I've also tried every other possible connection there is and no difference). Static IP set to 10.14.44.6 mask 255.0.0.0
The FRC cRIO Imaging Tool opens and sees the cRIO as 10.14.44.2
When the imaging tool tryes to connect it give me the error "The specified IP address is unreachable. Ensure that the IP address is on the correct subnet."
I've disbled the PC firewall and disconnected from the wireless network.
I have been able to connect a few times after reconfiguring/reseting. Don't know why. The reimaging gets started but then I get an undexpected error 60. The next time I try, I'm back to the first problem.
Any advice?
Unread 30-12-2008, 21:11
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Problems reimaging cRIO
See if this works: http://www.chiefdelphi.com/forums/sh...8&postcount=17
Unread 30-12-2008, 22:33
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Ravena,
When we imaged the cRIO, we didn't use the crossover cable and we left it plugged into the the webcam. We then took an ethernet cable from port 1 on the cRIO to one of the ports on the driver station. Then, and ethernet cable from the other port on the driver station into the laptop. Power on both devices, driver station and cRIO.
Your laptops static IP should be set to 10.0.0.6, and NOT the IP with your team #. I'm not sure how your teams number would already be in the cRIO if this is first time you have imaged the cRIO. When you open the cRIO imaging tool, the "current IP" will be in the far left column of the device table. The subnet mask should be set to 255.0.0.0
Unread 30-12-2008, 22:43
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Also try another computer. We had all kinds of headaches that went away when we switched to another computer.
Unread 31-12-2008, 11:50
sayso_411's Avatar
sayso_411 sayso_411 is offline
10 Years of Sparky!
AKA: Shaav
FRC #0384 (Sparky)
sayso_411 can only hope to improve
I totally agree with Hadi379...we had the same problem and i believe by changing the ip address it fixed the re-imaging issue
good luck!
Unread 31-12-2008, 18:23
Thanks to everyone who replied.
Here is where I am at:
-It seems like when I tried the reimage, the IP address of the cRIO got set at some point in one of the trys. I was able to ping it using 10.14.44.2.
-I tryed using the Measurement and Automation utility and it found the cRIO and also said the IP was 10.14.44.2. I was able to change Development Environments but not reimage, so I am talking to the cRIO.
-I tryed a different computer (set to 10.14.44.6) and it worked. I found later that the computer that worked had update FRCLabVIEWUpdate1.0 instead of 2.0. Now I'm afraid to upgrade to 2.0.
Thanks,
Tony
Team 1444
Unread 31-12-2008, 23:11
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
When we switched computers and the reimaging started working, we had the 2.0 upgrade, so it seems that switching computers has helped in more than one instance.
Sure wish we had a definitive reason why a computer switch seems to clear up this problem.
Unread 01-01-2009, 14:32
I tryed again today with my new laptop to reimage the cRIO and same problems.
I upgraded my standard computer to FRCLabVIEWUpdate2.0.zip and it reimaged the cRIO just fine. ???? Only difference is laptop is Vista and standard computer is Win XP.
Thanks,
Tony
Team 1444
Unread 01-01-2009, 23:07
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
go into network connections and go to the properties and then change the ip address for the port and then it should read it. Then reset it with the imaging tool and then you are all set... if you still cant get it i can make a video or something....
Unread 10-01-2009, 17:19
pheisinger pheisinger is offline
FRC #1985
pheisinger is an unknown quantity at this point
Angry Re: Problems reimaging cRIO-us too!
We're also having problems. PC is set to 10.0.0.6 and plugged into Ethernet 1 on the cRIO via a crossover cable. I can ping 10.0.0.2 but the cRIO imaging tool tells me no cRIO found. This is our first attempt after trying out all of the initial bench tests - we haven't communicated with the cRIO before.
Unread 11-01-2009, 21:52
FRC #1985
Smile Re: Problems reimaging cRIO
Problem resolved - disabling all other networks on the PC seemed to help the most. Was also able to see cRIO in MAX and originally changed IP address there.
Unread 09-02-2009, 22:03
PHSRobotics PHSRobotics is offline
FRC #2135
PHSRobotics is an unknown quantity at this point
Should we need to continue reimaging our cRIO every time we want to download code? Our driver's station doesn't work unless we reimage the cRIO but we were unsure if this was a normal problem.
Unread 11-02-2009, 19:42
You should only have to reimage the cRIO once with an update. The image then remains in nonvolatile memory. You have to use the same reimaging tool to switch between booting to C or booting to LabView, but that is only the check box at the top of the tool. You do not have to reimage.
Tony
Thanks,
Tony
Team 1444
Unread 17-02-2009, 20:19
Looks like this problem has been fixed with the FIRST Robotics Competition Software 2009 Update 3
Readme file states:
Bug Fixes
- Fixed an issue in which running the CompactRIO Imaging Tool on Windows Vista returns unexpected error 60.
My Vista laptop worked fine with this update.
Thanks,
Tony
Team 1444
Problems undeploying a program from the cRIO ellisk Programming 2 29-12-2008 16:21
cRIO interrupted during reimaging rsisk FRC Control System 23 21-12-2008 22:41
HELP reimaging RMS11 Control System 4 17-12-2008 21:21
