Go to Post I think that one of the most fantastic parts about FIRST is that the biggest and most successful teams are also the most abiding to the rules. - Matt Adams [more]
Unread 11-02-2009, 19:42
agough's Avatar
agough agough is offline
FRC #0234 (Cyber Blue)
agough is an unknown quantity at this point
Question Encoder Limit
Is there an encoder limit?
I ask because when we build our program with 5 encoders used throughout it builds fine and it downloads but when we start it up our program won't run and tells us:
"Cannot allocate any more ports" check Resource.cpp line 61
We found nothing in Resource.cpp that is relevant.This is function/line it tells us to check(_=Space):
UINT32 Resource::Allocate()
____for (UNIT32 i=0; i < m_size; i++
____{
__________if ( ! m_isAllocated[i])
__________{
__________m_isAllocated[i] = true;
__________return i;
__________} <-This is line 61
____}
____wpi_fatal(NoAvailablePorts);
____return 0;
If we comment out at least one encoder object creator and pointer(and it doesn't matter which one of the five we comment out) then the error doesn't show and everything else works.
"By failing to prepare, you are preparing to fail."-Benjamin Franklin
"Wise men talk because they have something to say; fools, because they have to say something."-Plato
Unread 11-02-2009, 19:53
Re: Encoder Limit
From the "C/C++ Programming Guide for the FIRST Robotics Competition"
There are four QuadratureEncoder modules in the FPGA and 8 Counter modules that can operate as
quadrature encoders. One of the differences between the encoder and counter hardware is that encoders
can give an oversampled 4X count using all 4 edges of the input signal. Counters can either return a 1X or
2X result based on one of the input signals. If 1X or 2X is chosen in the Encoder constructor a Counter
module is used with lower oversampling and if 4X (default) is chosen, then one of the four encoders is
used.
Limit Switches popnbrown NI LabVIEW 1 10-02-2009 22:39
Screwing Encoder into Encoder Mount? Adrien Electrical 3 25-01-2009 18:14
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
Spending Limit? Chuck Glick General Forum 8 08-01-2006 17:54
$$ Limit? Stephen Kowski Rules/Strategy 1 08-01-2002 00:01
