Go to Post P.S. No matter what happens a build season, you will always have memories. - Briansmithtown [more]
Unread 11-02-2009, 19:47
RedHeadRobotics's Avatar
RedHeadRobotics RedHeadRobotics is offline
AKA: Brigid
FRC #2081 (Icarus)
RedHeadRobotics will become famous soon enoughRedHeadRobotics will become famous soon enough
Question: Dip Switches on Robot Controller
Hey, does anyone know if in autonomous mode the robot will be able to read dip switches on the robot controller?
We would be using it to set which autonomous mode we would use, but we don't know if the robot can communicate to the robot controller to sense the dip switches.
If someone knows anything about this it would be really helpful.
Thanks
Unread 11-02-2009, 19:48
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Re: Question: Dip Switches on Robot Controller
You will need to be more specific than "robot controller". This is not a common term for any of the parts of the control system this year.
Are you perhaps referring to the Driver's Station?
Unread 11-02-2009, 19:54
AKA: Brigid
FRC #2081 (Icarus)
Yes, the drivers station. Or will we need to hook it up to the inputs on the robot?
Unread 11-02-2009, 20:04
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The robot will not be able to receive input from the DS during Autonomous/Enabled mode. It will be able to receive information during Autonomous/Disabled mode.
According to Team Update 9 the following sequence will be followed in the match:
During each MATCH, the Field Management System will cycle each Driver Station though
the following states:
* Autonomous - Disabled
* Autonomous - Enabled (for 15 seconds)
* Teleoperated - Disabled
* Teleoperated - Enabled (for 120 seconds)
See this thread for more information
Unread 11-02-2009, 20:17
AKA: Brigid
FRC #2081 (Icarus)
thanks for the link, it helped a lot
Unread 11-02-2009, 21:29
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Is it safe to assume that the USER1 Dip Switch on the cRIO will be readable during Autonomous mode?
Robot controller lights question Dr Theta General Forum 2 26-02-2008 08:58
Robot Controller Question (team 585) Pligon Rules/Strategy 5 18-02-2008 04:48
General question about the robot controller itsme Technical Discussion 6 14-01-2007 15:33
Question About Robot Controller Pavan Dave Control System 4 03-01-2007 11:14
DIP/SIP resistors John Gutmann Electrical 9 26-08-2005 20:27
