Go to Post We're 30 pounds over LOL. I probably shouldn't be lol'ing, but it is 11:52PM, I just got home from a 15 hour build session, and I find the word 'potato' funny. - ZakuAce [more]
Unread 11-02-2009, 20:36
TERTOLA TERTOLA is offline
FRC #2513
TERTOLA will become famous soon enoughTERTOLA will become famous soon enough
Electrionic Board Troubleshooting
On our electronic board now, just powering it up for the first time, we are getting some trouble now. When the boards light, light up, everything does except the Digitial sidecard and the jaguar speed controls don't light up. They are all wired correctly and double checked. Any hints on as to what the problem is?
Team Year 2001 - Life
Team Year 2002 - Life
Team Year 2003 - Life
Team Year 2004 - Life
Team Year 2005 - Life
Team Year 2006 - Life
Team Year 2007 - Life
Team Year 2008+ - Still got lives, but with a robot.
Unread 11-02-2009, 20:46
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: Electrionic Board Troubleshooting
did you remember to put in the fuses in the power distribution box? both the jags and the side car work off of there so that could be your problem.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 11-02-2009, 20:58
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Would it be possible to post a picture of your wiring? When you say that everything except the DSC and Jags powered up what all does this include?
You may want to make sure that the Wago terminals are grabbing only the wire and not the insulation. This appears to be a common error when using these terminals.
Also my Thursday class is canceled this week due to damage to the EE building so I could probably come by anytime tomorrow if you are interested. Send me a PM, email or give me a call (I believe I PMed you my info a while ago).
Unread 11-02-2009, 21:12
FRC #2513
Yes, i will def stay in touch, we have much work to be done, ill discuss it with our advisor when i see him. I'll PM you sometime early morning tomorrow. But I will check our wiring and all again. Much thanks!
Unread 11-02-2009, 21:17
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
A very common failure is to strip too little insulation off the wires into the PD. As a result, a few teams have had Digital Sidecars that looked like they were wired properly but, in fact, weren't getting power.
If the 5V LED on the Sidecar is lit but faint and the 6V and 12V LEDs are off, you probably need to remove some more insulation from the wires in the PD and reinstall the cables.
You could also have the wires swapped at the Sidecar's power input.
Make sure all 3 of the Sidecar's power LEDs are on.
Russ
PID Troubleshooting iamthewalrus135 Programming 7 08-02-2008 11:16
Firefox troubleshooting. Madison IT / Communications 11 17-09-2006 01:28
PID Troubleshooting Disar Programming 4 13-09-2006 15:27
Troubleshooting - 783 lee87 Website Design/Showcase 2 13-02-2005 20:15
Troubleshooting System SilverStar Technical Discussion 0 23-01-2004 21:22
