Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 31-01-2009, 11:38
atr15566 atr15566 is offline
FRC #0203
atr15566 is an unknown quantity at this point
Update 3a Problem
After trying to correct new problems with the update, I'm stuck. When we try to run the program, an error 44085 "Library Expecting Version 2009, 1.0.0" keeps appearing. After continually pressing continue, I get an Error 7 "Call Library Function Node in DriverStarion.lvlib:Start Communication.vi->Untitled 1". After stopping we get Error 63192 "_nirio_device_open.vi:1". We reimaged cRIO twice, and got the same problem.
Unread 31-01-2009, 12:10
TDohse TDohse is offline
AKA: Thomas
no team (NI)
TDohse is an unknown quantity at this point
Re: Update 3a Problem
This looks like you have the latest software on your PC, but not on the cRIO. 1.0.0 is the final FPGA revision. Can you verify that you reimaged with FRC_2009_v11.zip successfully? The FPGA version and revision are printed to console at boot if you have the console out toggle switch set to On. You can also ftp to the cRO and look at the frc image version text file.
Unread 11-02-2009, 22:27
Bobert's Avatar
Bobert Bobert is offline
FRC #0696
Bobert will become famous soon enoughBobert will become famous soon enough
I also have the same problem. I've updated the cRio, labview and the DS. Still can't deploy.
Unread 12-02-2009, 07:51
When you updated the cRIO, did you format it? If it took thirty seconds, you forgot to hit the checkbox to format. Formatting takes about fifteen minutes.
Greg McKaskle
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
Control System Update Problem tubeheaD37 FRC Control System 6 11-01-2009 20:42
Update #14 ChuckDickerson General Forum 2 23-02-2007 22:51
Update 12 Tomasz Bania General Forum 1 25-02-2006 13:59
