Go to Post If you don't like getting tipped don't build a robot that tips. - Koko Ed [more]
Unread 11-02-2009, 22:25
Jack Gillespie's Avatar
Jack Gillespie Jack Gillespie is offline
FRC #5430 (Pirate Robolution)
Jack Gillespie is an unknown quantity at this point
cRio not working...?
We're trying to deploy the labview code to the cRio. However, the cRio (10.xx.yy.02 and .03 ) ip addresses/devices are not showing up, which (WE THINK) is why we can't download/deploy anything to the robot. We can see .01 (the bridge), .04 (the ds wireless), .05 (the ds), and .06 (the computer).
My question is, could the cRio somehow be broken/fried and how would we tell? It still has the little green lights that light up when the ethernet cord for the bridge is plugged in.
Unread 11-02-2009, 22:32
Re: cRio not working...?
If you no longer get lights of any sort to come on on your cRIO, then will have a chance to send it back in.
Greg Mckaskle
Unread 11-02-2009, 22:37
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Actually you have power if the ethernet lights are on. Is the status light blinking?
Unread 11-02-2009, 22:42
The little green lights on the red cards are all on. the green light next to the word "power" is on. when the robot is first turned on, the yellow light next to the word "status" lights up, then turns off.
But it doesn't blink or reappear again.
Still confused, though. (See, I am so not a programmer here!)
Unread 11-02-2009, 22:52
AKA: Chris Rake
no team (Athena)
Looks like the cRIO successfully booted and is ready. I know other teams have had similar configuration issues - let me see if I can find some posts...
Unread 11-02-2009, 22:54
The only thing is, we've never gotten to deploy the actual labview robot project code. Everytime it says "trying to connect to the cRio" message and doesn't get through. That's why we looked at the linksys manager and found out that the .2 and .3 aren't showing up. We freaked out that we had somehow fried it. So if it's all booted and ready and stuff, I'm confused why it doesn't ever say it was deployed successfully....
Thank you, though! You've made me much much less anxious that we had somehow killed it.
Unread 11-02-2009, 22:56
AKA: Chris Rake
no team (Athena)
Here's a similar thread http://www.chiefdelphi.com/forums/sh...ad.php?t=73620
Unread 11-02-2009, 23:05
Ok, read through that. I'm not sure what all that means, though. That had a .2 and they were trying to update? We don't have the .2, and I guess we're trying to update too. But honestly, I'm clueless. I can get the crio hooked up directly (like the thread said), but it still won't show a .2 or a .3. I'll go try again, though.
Thanks again - I printed out that thread to take back to the other room (where the robot is doesn't have a wifi for internet, only for the crio. sucks!)
be back shortly!!
Unread 11-02-2009, 23:24
ok, here i go again.
I tried hardline connecting ds-laptop-crio like the other thread mentioned. Even when plugged directly into the crio, I did not get the .2. Meaning that the computer/system is not reading the crio at all.
Now I'm completely confused, because it was directly connected to it!!
Unread 11-02-2009, 23:25
AKA: Chris Rake
no team (Athena)
Assuming you have a good link (Enet lights are lit and blinking), can you ping the controller at all? Any reason you might have changed the IP address? Have you read the instructions in the previous link or tried the network address changes?
Unread 11-02-2009, 23:33
...um, ok, will run up there again and ask the other teacher to do that (I'm the math side, he's the electronics side). But I don't have a clue what that means, personally.
Nope, and there's only one IP that we can easily change (the laptop), which isn't the problem.
Read the instructions, gave to jack (the other teacher) to read and make sure we had tried that, but I think the changing of the laptop isn't the problem - it's getting the cRio to respond, and we didn't see that happen when we changed the ip earlier.
But will try again after printing out this thread too, so jack can check that I have done the things you and the other thread suggested.
be back shortly! Fingers crossed....
Unread 11-02-2009, 23:36
AKA: Chris Rake
no team (Athena)
In the morning, if you're still stuck, please visit ni.com/first and we can help.
Unread 11-02-2009, 23:42
well, we pinged it, and it responded. Very pleased!
Here's what Jack and I realized might be the issue - our DS is saying"Battery: 00.00V" when we've tested the battery on the robot and it is running 12V (actually, when we checked, 12.96 or something.) Wondering if that could be the issue and it's why we can't see/talk to the crio?
Unread 11-02-2009, 23:49
AKA: Chris Rake
no team (Athena)
That's a good sign! But I'm pretty sure it isn't the battery voltage. If the lights are on, and you can ping the device then the cRIO is up and running. 12V battery output should result in a healthy 24V going to the controller. It seems like an imaging problem, and you should be able to follow the imaging steps and get up and running from this point.
Unread 12-02-2009, 18:56
Wow! You were so helpful last night. Now we can deploy all of it, but 2 things crop up.
1. During build, it says it prevented a "file name error" or "duplicate file error" or something. We think it means 2 files are named to same thing? Have you any clue how we could find out WHICH file is the problem?
2. during deployment, it says that it failed to deploy/load startuplibrarypatch.out (i may be missing a space, it was last night). Joysticks and auto mode still do nothing, however.
Any ideas? I have the kids searching the computer/project for the file, but otherwise I'm still stymied, because if it deployed everything else, shouldn't it work somehow?
THANKS!
cRIO Not Running Program railerobotics NI LabVIEW 5 18-01-2009 08:48
DS and cRIO Not Maintaining Communications Will_Sica FRC Control System 0 10-01-2009 13:39
CRIO not working with Windriver dpeterson3 C/C++ 7 07-01-2009 20:49
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
