Go to Post John Abele certainly deserves much more recognition than he gets. - Richard Wallace [more]
  #31   Spotlight this post!
Unread 11-02-2009, 16:45
Rex Woodu Rex Woodu is offline
AKA: Eric
FRC #2474 (Excel)
Rex Woodu is an unknown quantity at this point
Re: Dumpers?
How does shooting make it harder to program than dumping?
  #32   Spotlight this post!
Unread 11-02-2009, 16:53
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Dumpers?
Many people (me included) believe that to be very effective a shooter will need to automatically target opponent's trailers. These trailers will be moving so a shooter will likely need to not only find the trailer, but also figure out how to lead it and shoot were it will be when the ball gets there and not where it is.
You can have an effective dumper that relies on driver skill for positioning, but it will likely be much more difficult to do so with a shooter.
  #33   Spotlight this post!
Unread 11-02-2009, 23:15
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: Dumpers?
One good thing about dumpers is the way they self-align on impact with the target trailer (not just for aiming, but also for distance). With a wide aspect ratio, you get a 25" wide ball collector opening between the 6" bumper segments. When you make contact with the hexagon shaped trailer (moving or stationary) on this slick surface, the robot and trailer shift to bring everything into proper position and alignment. A "bump & dump" bot that can unload in a second can score almost 100%.
Shooters have the advantage on distance, but they are at the mercy of technology or luck to toss a ball inside a 25" circle.
As for finding stationary robots, have you ever seen an FRC game where robots weren't stuck in traffic jams? Even overdrive had lots of stopped robots.
  #34   Spotlight this post!
Unread 11-02-2009, 23:25
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
Re: Dumpers?
Team 2915 is building a dumper.
we use a conveyor system in front to pick up balls, then, we use a pneumatic actuator to lift the bottom of our hopper (holds 6 balls) till it tips them out the front of the bot. it easily gets at least 2/3 of the balls in the oposing team's trailer...
basically, we drive up behind another team, and dump... we don't need to stop, as the forward momentum seems to help the balls come out of the hopper (i know, physics say that momentum shouldn't matter, but, in the words of adam savage: "I reject your reality and substitute my own")
we can also drive up to the side of a trailer and get most of the balls in.
the belts also hold an additional 5-6 balls, and are reversible, so that you can eject balls to the human player if needed.
-Z
[center]
  #35   Spotlight this post!
Unread 11-02-2009, 23:35
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Dumpers?
Our programmers should know the answer to that... they've been madly programming our robot for about 3 weeks now! We're making an attempt at hitting a moving target, and I can confidently say that this is the most technologically complex robot we've ever built (by far!).
If we didn't have programmers working on the automatic aiming turret, I think a dumper would have been the only sensible robot to build. Fortunately we have a lot of programmers this year, and it's turning into a really nifty project.
  #36   Spotlight this post!
Re: Dumpers?
We're dumping using pneumatics.
We're a bit worried at this time about having a finished robot though...stupid snow days killed us this year.
Pneumatics are killing weight as is our ball conveyor...I'm not too optimistic about this year.
  #37   Spotlight this post!
Unread 11-02-2009, 23:36
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Re: Dumpers?
team 342 dumper video
Here is our dumper. The video was taken before fine tuning, but we still got 75% in. We are now at about 85% - 90% getting in the trailer. 2 Jaguars, 1 victor, 1 spike, actually following KISS- priceless
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
  #38   Spotlight this post!
Unread 11-02-2009, 23:47
Re: Dumpers?
Our bots would be such good alliance partners....more like twins.
Great bot. Ours is basically the same, I didn't like the KISS factor of our robot this year because I like machining complex parts plus there weren't many things to build. hehe
  #39   Spotlight this post!
Unread 11-02-2009, 23:52
hipsterjr's Avatar
AKA: CJ
Re: Dumpers?
Sure, shooters have the potential to be high scorers. But the way I see it, dumping is just so easy and efficient.
  #40   Spotlight this post!
Unread 12-02-2009, 06:52
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Dumpers?
Here is our dumper.
Have you tried it with the bumpers on your robot, when you're 3.5" farther out from the trailer?
I agree properly built dumpers, especially those with power assist exiting, can be very effective.
(since 2004)
  #41   Spotlight this post!
Unread 12-02-2009, 09:00
hipsterjr's Avatar
AKA: CJ
Re: Dumpers?
wait, we have to have bumpers lol. No, we just put the bumpers on today, I'll have some video of it dumping with the bumpers once I get caught up on homework.
Any others with dumper video?
  #42   Spotlight this post!
Unread 12-02-2009, 09:56
Badflea's Avatar
Badflea Badflea is offline
NOooooooooooooo....!!!
AKA: Jason
FRC #1758 (TechnoMancers)
Badflea will become famous soon enough
Send a message via AIM to Badflea
Re: Dumpers?
We're working on a "Power Dumper".
Basically a cross between a dumper and a shooter.
Ah..long range dumper.
I'll try to post a video later this week.
  #43   Spotlight this post!
Unread 14-02-2009, 03:01
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Re: Dumpers?
I just revised our method.......I had some other people come up with a design, which turned out to be an un-aimable shooter. See as this is also our first year, and we started building this last week, a dumper seems the best choice.
We'll see!
  #44   Spotlight this post!
Unread 14-02-2009, 07:48
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Dumpers?
We Finally worked most of the bugs out of our powered dumper. It's able to offload 10 balls in about a second with a maximum range of about 1 foot.
We've codenamed it "The Shumper"
I think Dumpers will have a significant advantage in the number of balls scored in one instance. Our robot for example can hold 20 balls and we can offload them with about 80% accuracy in 3 seconds or less. As long as you have a good driver behind your dumper you'll be a force ot be reckoned with.
-Dustin Benedict
  #45   Spotlight this post!
Unread 14-02-2009, 10:10
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
Re: Dumpers?
I agree^^
Our robot sounds very similar, with a holding capacity of about 18 and the ability to power dump all of them within a few seconds.
SBPLI Long Island Champions 2003 2005 2006
SBPLI Semi Finalists 2007 2008 (#1 seed) 2009 (#1 seed)
Galileo Finalists 2009 (thanks 1717 and 2775)
ball dumpers/throwers types wireties Technical Discussion 17 10-01-2009 20:06
how effective are the herders/dumpers? Mullen General Forum 46 03-04-2006 21:25
