Go to Post Are we really at the point where the only useful thing we can discuss is Dean's choice in timekeeping apparel? The man has a watch. He uses it to tell time. Do we really care how much it is worth, or who made it? I would be much more interested in what he does, not what he wears. - dlavery [more]
Unread 12-02-2009, 00:05
alleah2338's Avatar
alleah2338 alleah2338 is offline
FRC #2338
Team Role: Electrical
alleah2338 is an unknown quantity at this point
Red face How do you wire a rotating component?
So my team this year is using a shooter device and the design is for the shooter to rotate. Since this only our second year we have no idea how to wire the motor since it is attached to the shooter. We would like to do it without wires hanging everywhere. We have search how to slip mount them and haven't found anything. In past years books we have seen teams who have done something similar and can not figure out how.
Does anyone know how to do this?
Unread 12-02-2009, 00:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How do you wire a rotating component?
Route the wires carefully.
We're facing the same problem, we made a pole that sticks up behind the turreted shooter, and the wires go forward from there to the top, center of the shooter. Haven't tested it much yet this way...but the wires did survive a couple weeks of testing when they were just hanging all over the place.
Our turret only moves 180 degrees or so. That might be different than yours.
Using slip ring contacts is a tricky business!
Unread 12-02-2009, 00:09
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
either using these: http://www.mercotac.com/html/430.html
or simply limiting the rotation of the device to 180 or 360 degrees, and letting the slack in the wire make up this distance.
Or, by putting the wires through the igus energy chain, and having the chain wrap itself around the turret as it rotates, while giving the chain space to expand to as it rotates the opposite way.
Unread 12-02-2009, 00:13
alleah2338's Avatar
FRC #2338
Thank you. I will try some of these ideas tomorrow. Our shooter only rotates 180 degrees. We have thought about tying them down with elastic so they can move but still be held tight. Has anyone tried that?
Unread 12-02-2009, 01:14
EricH EricH is online now
What you can do in that case is: run the wires to the midpoint before tying them down. One of the ends will also do; the midpoint is just to reduce the length of wire you'll have to bundle and pull out of the way. Now, rotate the shooter to the maximum rotation in both directions, using a piece of string to simulate the wire. The most the string pulls out is how long you need your wire to be.
Having something to keep it out of the rotating components is good; try surgical tubing. It's easier to work with than elastic for this type of thing.
The one time my team needed to have wires move with something, it was a lift (with an arm on top, and the arm motors were on the arm), and we simply figured the max length we needed and made a pretty thick cable to run from the top of our base to the top of the lift and looped it into the robot so it hung freely.
Unread 12-02-2009, 07:49
alleah,
Will I be seeing you this weekend? If so we can discuss this when I see your robot. As a general rule, if you can keep the wires near the center of rotation and leave a little slack, you will be able to turn without damaging the wires. If that is not possible, something like what Jim discussed above will work fairly well. Remember that latex is robot legal and easy to use as a springy tie point for a wiring bundle to keep it out of harms way.
The slip rings shown in the post above use mercury and as such have been ruled to be illegal on our robots. There are however, legal, brush type, slip rings that are available. McMaster had a few in previous years. They are pricey but fit under the single cost rule as I remember.
Unread 12-02-2009, 08:21
in between teams
AKA: Luke Van Oort
That isn't quite right, they have been ruled legal in this year's competition: http://forums.usfirst.org/showthread...hlight=mercury. (I believe there were similar Q&As since at least '06, but I never really paid them much mind - my team always used the bundle as close to centre as possible approach)
Team 1219: 2009 - Mentor
Unread 12-02-2009, 08:26
Sorry,
I hadn't seen that question. In the past, this coupling was considered hazardous as a robot collision could open the coupler and expose the mercury. The coupler has some very strict handling and mounting instructions that must be followed. I will make sure the Inspection team is made aware of the answer.
How do you wire up the Operator Interface? iPilipino Electrical 6 22-01-2008 00:22
How do you wire the wheel encoders? Demothesis Electrical 2 17-07-2007 16:59
how do you wire the team light coolguybigt Robot Showcase 2 21-02-2007 22:18
How do you wire a limit switch? JMH Electrical 1 16-02-2005 17:44
How do you wire ADXRS150EB gyro? MaxM Electrical 2 16-02-2004 13:43
