Re: Struggling To Program CRIO
We also somewhat had a similar problem, first if you just turned on the main breaker, what a bit to check if it still says "no comm" the cRIO has to startup. If it still says that check all of your connections, are you using the right ethernet cables in the right spots. If you get a voltage, and you get a voltage of "0" but you know that is not true(this was what was happening with us), we ended up needing to reimage the cRIO(especially since LabVIEW update 3). That is my two bits of advice. Also for next time if possible add some pictures, pictures help so we can see your wiring and other stuff instead of just having to make lots of random guesses.
Ill get some pictures tomorrow, did not think to take any before leaving.
We have tried tethering, but my guess is that the board is not wired up. The sidecar is the only thing plugged into the CRIO. The other modules are plugged into the CRIO but don't have cables going to them. |
As stated above, your CRIO is not connecting to your Driver Station. Make sure that your driver station and CRIO are on the same team number. The documentation for that is on the first site. If you changed the number on the driver station, that does not mean that you did so for the CRIO. To change the number for the CRIO, you have to flash it and check the format button, using the right team number.
| cRIO Program Delay | bomber7 | Programming | 2 | 29-01-2009 21:35 |
| cRIO Not Running Program | railerobotics | NI LabVIEW | 5 | 18-01-2009 08:48 |
| it seems there is no program in crio after downloading | mahmosh | C/C++ | 12 | 12-01-2009 18:53 |
| cRIO wont save program | Arcre | NI LabVIEW | 5 | 07-01-2009 11:45 |
| Problems undeploying a program from the cRIO | ellisk | Programming | 2 | 29-12-2008 16:21 |
