Go to Post this is ridiculous, a complete waste of time, and probably not particularly effective. I love it! - The other Gabe [more]
Unread 12-02-2009, 09:12
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
problem while programming 2 bottuns in windriver
hey
we are trying to do 2 buttons for the same motor if button 1 pressed move forward .. else stop ... and then if button 2 pressed move backward else stop
here is the code we are using but it doesn't work well :
in the operatorcontrol we put this:
if(leftjoystick->GetRawButton(1));
jaguar->Set(1.0);
else{
jaguar->Set(0.0);
if(leftjoystick->GetRawButton(2));
jaguar->Set(-1.0);
else{
jaguar->Set(0.0);
what is the problem with this ?? if we deleted the second part
jaguar->Set(-1.0);
else{
jaguar->Set(0.0);
everything working ok!!
please need answer
WindRiver Programming Template kyungjin C/C++ 0 24-01-2009 16:42
Potentiometer on cRIO, Programming in Windriver sircedric4 C/C++ 3 20-01-2009 06:42
WindRiver Programming dnrobotics11 C/C++ 1 19-01-2009 20:13
WindRiver Programming dnrobotics11 C/C++ 4 19-01-2009 19:43
Problem debugging code with WindRiver LinuxMercedes Programming 3 07-01-2009 11:10
