Go to Post I thought we agreed to just put up a teaser, not a picture of the robot! - IBdrummer [more]
Unread 12-02-2009, 09:16
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Inventor Wire Problem
Hey all. I'm in the process of wiring our robot up in inventor and I have a problem. Is there anyway to make the pins and yellow lines invisible in the harness drawing. For wires/segments I've already created, it gets quite annoying. Someone help! Thanks!
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 12-02-2009, 10:19
Re: Inventor Wire Problem
Josh,
Not sure that this is what you are trying to do, but have your tried using different layers to control visibility?
Unread 12-02-2009, 15:45
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
It's been a while since I've done this...can you turn it off in the View menu under object visibility?
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 13-02-2009, 01:32
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
As far as the Pins go visibility is your best bet but the yellow lines should go away when you route the wire
this is a great refrence tool if you need it
http://www.chiefdelphi.com/forums/sh...ad.php?t=64206
wire on Inventor kamikazi521 General Forum 1 05-02-2009 09:31
Creating Cable/Wire systems within Inventor Vanill4Gorill4 Inventor 1 10-01-2009 13:31
Inventor problem FIRST JerseyKid Inventor 6 21-05-2007 21:33
Odd Inventor problem teamtestbot Inventor 11 07-12-2005 00:20
Possible Wire Problem? D.J. Fluck Kit & Additional Hardware 2 17-02-2002 03:28
