Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Unread 12-02-2009, 09:32
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
how do I ramp up the wheels slowly
I am trying to create some code in Labview so i can ramp up and ramp down the speed of the wheels but i don't know where to start. like to slowly go from the value of 0 to the max speed of -1. i tried to do this with a while loop but failed because i could not find a variable such as x. any suggestions?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 12-02-2009, 09:34
Re: how do I ramp up the wheels slowly
http://thinktank.wpi.edu/article/140
Hopefully this document will help.
Unread 12-02-2009, 10:02
seanl's Avatar
this is for the drive of a motor without the use of a joystick, i am using a button to drive the whole robot forward but i need it to ramp up. but thanks for the information on making the joysticks smoother.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 12-02-2009, 10:22
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
I haven't read Eric's article but the use of filters isn't limited to floating point joystick position readings. You can also take a boolean value, convert it to a floating point 1 or 0 ("boolean to 1:0") and then pass the value through a point-by-point or similar lowpass filter (this is probably one of Eric's suggestions). The filter cut-off frequency would dictate the response time.
You could also pass the 1:0 value through a leaky integrator (if 1 then add a little bit (clamp to max value), else decrement a little bit (clamp to a min value)).
Russ
Unread 12-02-2009, 10:40
I've attached a picture of a leaky integrator.
I used the boolean select to convert a boolean to one of two floating point values - in this case, how much to add or subtract each time the code is executed.
I used a feedback node (the arrow) to remember the last value.
I used the coerce and in range to limit the max forward or reverse speed.
Unread 12-02-2009, 17:00
seanl's Avatar
Eric, i tried what you stated in your paper and it looks like it could work, can you or someone else check and see if it is right. i put a constant of 1 instead of the "input from joystick". theoretically this should allow the robot to slowly back up.
P.S. the code is attached to this post.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 12-02-2009, 18:57
dmcguire3006 dmcguire3006 is offline
FRC #3006 (West High FIRST Robotics)
dmcguire3006 is on a distinguished road
Use a PID Controller:
http://en.wikipedia.org/wiki/PID_controller
There provided as a VI in Labview.
Unread 12-02-2009, 19:11
seanl's Avatar
are there any documentation on using a PID controller being that i am a novice at labview programming. And is there an advantage to using a PID controller over the method stated above?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 12-02-2009, 19:26
PID controllers are very powerful, but in this case they are probably over-kill.
I would recommend using one here in place of a leaky integrator only for the learning experience - you will find it very helpful in the future. That being said, leaky integrator is probably the way to go here if you are aiming for simple.
Unread 13-02-2009, 00:13
chmp09 chmp09 is offline
AKA: Marc Pulte
FRC #1702 (Robocubs)
chmp09 is a jewel in the roughchmp09 is a jewel in the roughchmp09 is a jewel in the rough
I use a lead-lag PID controller to control our ramping, and it works really well. It will take some tweaking, but it is not that difficult.
For basics, just set you [EDIT] output range to -1 and 1. Set you gain to 1. Set your lag time to whatever you find is best (ours is .2); this changes how fast it ramps. Set lead time to zero. Set dt to -1(sets it to milliseconds). [/EDIT] You may want to tell it to reinitialize at values of zero because it will also ramp down.
The code attached was made for ramp code on a tank drive robot.
How do you make your compressorless system work, when all valves "bleed" air slowly? kmcclary Pneumatics 9 17-02-2007 21:01
Q&A Discuss: How long is the bump from the ramp to the top? CD47-Bot Extra Discussion 1 11-01-2003 09:48
How long is the bump from the ramp to the top? Tton Rules/Strategy 1 09-01-2003 18:26
How will the bins face on the ramp? Jacqui Sutton Rules/Strategy 1 07-01-2003 08:48
How much force to push the ramp? archiver 2001 1 23-06-2002 22:44
