Go to Post When mentors and students battle it's the team that loses. - Koko Ed [more]
Unread 12-02-2009, 12:55
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
Re: Servo questions...
Thanks for the quick reply -- gotta place an overnight order real soon here.
Nope. The FTC servos are explicitly allowed separately from the rest of the servos. Any servo that isn't FTC would have to meet the specs. (<R51-C> != <R51-B>)
That's clarifies that. Thx.
RE: doubling-up servos:
I see no rules against that. If there had been, then at least one team would have been jumped on about a week ago when they posted a picture of three that were obviously designed to work together.
Then that will probably be my solution... I can think of about 3 ways to do this (1) back-to-back with the signal reversed to one of them (2) dual control links from each servo's horn to the same fulcrum point on the controlled arm, or (3) gear on the controlled arm with servos pushing that gear at different points around the circumference of the controlled gear.
I can't find that post with the other team's implementation of this, so if you know any keywords to find that post, it would be much appreciated.
Much thanks!
-Neil.
Labview questions, using motor and pot as a servo martin417 NI LabVIEW 7 05-02-2009 16:43
servo on DS eitang FRC Control System 1 16-01-2009 14:32
Servo Connection questions Japper Electrical 8 03-02-2007 17:27
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servo MASherry General Forum 6 04-10-2004 22:46
