Go to Post it's flattering, but a little scary, because I don't know if I'm ready to be an inspiration! - MissInformation [more]
Unread 12-02-2009, 13:08
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
Robot Signal Light
We can't seem to figure out how to wire this. Can someone help? Please be specific with your directions and the materials that we will need. Thanks so much!
SBPLI Long Island Champions 2003 2005 2006
SBPLI Semi Finalists 2007 2008 (#1 seed) 2009 (#1 seed)
Galileo Finalists 2009 (thanks 1717 and 2775)
Unread 12-02-2009, 13:13
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Robot Signal Light
http://www.usfirst.org/community/frc....aspx?id=10934
Download the Power Distribution Diagram.
http://forums.usfirst.org/showthread.php?t=11829&highlight=robot+signal+ligh t
Use 22AWG wire per the Q&A response.
Feel free to use whatever connector you'd like to plug into the 2 pin port on the Digital Sidecar.
Russ
Unread 14-02-2009, 13:07
Blabbergase Blabbergase is offline
AKA: Adam
FRC #2197 (Las Pumas)
Blabbergase is an unknown quantity at this point
Does the Signal light need to be a certain height or does it just need to be visible?....
Unread 14-02-2009, 15:16
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
The rule does not specify any specific height. Wiring it looks pretty simple from examining the power distribution drawing.
Unread 14-02-2009, 15:17
Just visible from 3' in front of the robot in starting position. See <R58>.
Robot Signal Light smcmahon Electrical 20 08-03-2009 18:11
FRC Signal Light railerobotics Programming 1 07-02-2009 17:01
Signal Light DustinB_3 Electrical 10 21-02-2007 13:10
Whats the Robot Signal light for? steve d Electrical 12 20-02-2007 08:29
Robot signal light 11Mort11 Regional Competitions 11 19-02-2007 10:46
