Go to Post Edison was once asked "how do you come up so many good ideas?" to which he responded "for every good idea, I have 99 bad ideas first." - dlavery [more]
Go Back   Chief Delphi > Technical > CAD > Pro ENGINEER / Creo
Unread 12-02-2009, 13:21
PTC_FRC PTC_FRC is offline
PTC_FRC is on a distinguished road
Re: PRO-E TUTORIALS
Hi Murthy,
There are two ways to do this.
While in Assembly, you can select the component in the model tree and click the Right Mouse Button and choose activate. This will activate the part as if you where working on it by itself. You can add new features and edit existing features as you do in part mode. Give that a try. The nice thing about doing this in the assembly level is you can see how things interact with one another when making a change. When you are finished, click the assembly from the model tree and activate it via the right mouse button option.
Otherwise, select the component form the model tree and click the right mouse button and select Open. This will open the part in a new window.
Hope that helps.
Mark
Unread 15-02-2009, 14:45
ferc ferc is offline
ferc is an unknown quantity at this point
Re: PRO-E TUTORIALS
Hi Mark,
I would like to change the length dimensions of the c-channel imported from the CAD FRC library of parts.But when I try to right click the c-channel, no sketch feature or extrusion feature of c-channel appears in the model tree.
So i couldn't edit the sketch or extrusion length to change the length of the channel.Kindly let me know how to modify it.
thanks and regards,
Murthy
Unread 25-02-2009, 11:33
Re: PRO-E TUTORIALS
Hi Murthy,
Did you download the parts from www.ptc.com/go/firstkop? Or did you download it form the www.firstcadlibrary.com?
If you downloaded it from the firstcadlibrary.com, the files are not native Pro/E. You would not be able to modify the dimensions.
I suggest you grab the same model from the ptc.com site....as they are native Pro/E models.
let me know which ones you grabbed and we can discuss the steps to edit.
mark
Unread 26-02-2009, 14:16
Smile Re: PRO-E TUTORIALS
Hello Mark,
I think grabbed the parts from firstcadlibrary.com.But I'm almost done with the model now.However I'm terrible need of your help in conducting dynamic analysis which are described as follows:
(1) to determine the velocity at which if the robot hits an object it can tip off
(2) to check the displacement of the robot when certain amount of force is applied to the robot on its structure
I tried several online resources to find this but I could get any lead on this.
Can you clearly tell me how to conduct this.Also I think this portion of analysis was not available in the online classes.
Waiting for your support,
Thanks and regards,
Murthy
Unread 05-03-2009, 14:24
Re: PRO-E TUTORIALS
Hi Murthy,
Send me an email with the details and we can look at the problem.
mfischer@ptc.com
Thanks,
Mark
NI Tutorials comphappy Programming 0 18-08-2008 00:36
Tutorials RRA4LIFE2 Programming 1 06-01-2008 09:21
Whats your opinion, Pro-life or Pro-Choice? efoote868 Chit-Chat 5 28-09-2007 10:11
Easy C Tutorials jbbjjbt Programming 3 21-02-2006 08:40
Tutorials Leon Machado IV 3D Animation and Competition 13 25-01-2004 23:10
