Go to Post Keep in mind that the lady Amanda has just taken a new job, moved herself to the NorthEast, and has to put up with people like Grady, Needel, the Kelsos, and Boucher. Let's give her some patience and sympathy. - Andy Baker [more]
Unread 07-02-2009, 11:53
BrandonD-1528's Avatar
BrandonD-1528 BrandonD-1528 is offline
AKA: Brandon Dusseau
FRC #1528 (Monroe Trojan Robotics)
BrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the rough
Jaguar/Victor Not Getting Signal on Default Code
We're having trouble getting out Jaguar and Victor to get any signal from our driver station recently. We recently updated the cRIO to firmware v11. We think the possible causes could be that the driver station is faulty or that the cRIO could have been affected by an interruption during the update (our wireless bridge has a faulty power supply and shuts down randomly). We've switched out our jaguar and sidecar to see if they were damaged and they were not. If it turns out to be a faulty cRIO/driver station, I really don't think we'll end up competing this year. Any help you can offer is appreciated.
By the way, this is a team account, so random changes in the posting style are probably attributed to that. In response to a rather rude comment from one of our other threads, our main poster is dyslexic and has trouble spelling, so don't bother commenting about that again. Thanks.
Brandon Dusseau (website)
Monroe Trojan Robotics mentor
Software Engineer
Michigan Tech alumnus
Unread 07-02-2009, 12:30
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: Jaguar/Victor Not Getting Signal on Default Code
You should follow the the control system manualexactly. If you had, you would not have programmed the cRIO using the wireless link- you would have used ethernet cables and connected the Driver Station directly to the cRIO and your computer directly to the Driver Station.
With that being said, I can tell you that I have programmed the cRIO wirelessly and it's not reliable. The first time I did, it went half way through and told me it couldn't find the cRIO and displayed an error indicating it might be on a different subnet (it wasn't.) The second time, it worked... so my reccomendation is to go wired.
1.) What exactly does the battery status say on the driver station?
- If it say's "No Comms" you have a communication issue. Perhaps the team number isn't set correctly on the cRIO (set during imaging) or the driver station.
- If it says "No Code" you should re-image the cRIO using a wired link.
- If it says a reasonable voltage than we have to start looking in other places for the problem and will need additional information.
2.) What is the robot signal light doing on the digital sidecar?
Unread 07-02-2009, 13:36
Our battery voltage shows 00.00V all the time unless something is disconnected or we put our own code on it.
The lights are constantly solid green. We're not really sure what they mean though.
We imaged it while it was wired this time, but there still hasn't been any progress. Thanks for the help, but are there any other suggestions you can give us in addition to these?
Software Engineer
Unread 07-02-2009, 18:53
It's getting awfully late in the build, but it might be a good idea for you to start at the beginning and redo your control system while following the instructions to the letter. It sounds like you might have skipped a step or two, since you don't have the battery voltage being sensed properly.
There is a trio of pins at the end of the Analog Breakout opposite the power connection. You need to install a jumper between the two pins nearest the edge of the board in order to connect the battery sense circuit to the required analog input pin.
Which "lights" are solid green? There is only one Robot Status Light, and it is only solid when the robot is running code and enabled. Otherwise it is flashing.
Unread 12-02-2009, 12:59
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
We are having the same problem as discribed in this post.
If the analog breakout is not on the crio, will this cause the problem. We don't have the analog breakout on and we don't have the jumper on. What is the jumper, what does it look like, and can you give me very detailed instructions of how to wire it. thanks
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 12-02-2009, 14:22
If it is not properly installed and connected, the cRIO will have no way of measuring the battery voltage. See <R64>.
<R64> refers to Section 3.4 of the 'FRC Control System Component Data Sheets' which contains very detailed drawings and descriptions.
Unread 12-02-2009, 15:04
excel2474's Avatar
AKA: Aaron Stewart
FRC #2474 (Excel)
<R64> refers to Section 3.4 of the 'FRC Control System Component Data Sheets' which contains very detailed drawings and descriptions.[/quote]
Ok, Thanks, I'll take a look at that.
Unread 13-02-2009, 23:03
chmp09 chmp09 is offline
AKA: Marc Pulte
FRC #1702 (Robocubs)
chmp09 is a jewel in the roughchmp09 is a jewel in the roughchmp09 is a jewel in the rough
The good news is that your cRIO does have code on it, and that it is talking to the DS because your battery says 00.00V.
Your problem may be in the wiring. Make sure that all the slots on the cRIO are in the correct spots (Your digital sidecar should be connected to slot 4). Make sure that the digital sidecar has power. Though it seems pretty hard to overlook, teams have forgotten to do so this year. Finally, make sure that the pwms are hooked up correctly. They should be on PWM 1-4.
pic: Jaguar next to Victor ajlapp Extra Discussion 26 10-08-2008 17:56
Default code will not compile bronxbomber92 Programming 7 18-01-2008 18:44
Do not know where to get default code ZookieWookie Programming 4 13-02-2007 17:23
CMUcam default code not responding Kyveck Programming 29 26-01-2006 16:25
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
