Go to Post I think this post is a lot of words saying "My name is Billfred and I approve MiniBots 2017" - Andrew Schreiber [more]
Unread 11-02-2009, 20:04
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Angry autonomus mode
i can not make the aotonomus mode to control all four motor. how do i do that. and how do i make it go different ways. i got 3 days please help
Unread 11-02-2009, 20:05
Re: autonomus mode
please help
Unread 11-02-2009, 20:27
Re: autonomus mode
If you are starting with the original code, the main change is to change the Open for Robot Drive. It is opened in either Begin for the Advanced template, or in Robot Main for the Basic framework.
Greg McKaskle
Unread 12-02-2009, 16:19
Re: autonomus mode
I am using the one off of the basic robot main. i can not get it to control 4 motors please help me i do not have a lot of time
Unread 12-02-2009, 16:51
Re: autonomus mode
Does it control 4 motors in teleoperated mode?
Did you change anything in the Basic robot code to make it do that?
How are you trying to make it control 4 motors in autonomous?
What is it doing instead of what you want?
Do you understand Greg's advice?
Unread 12-02-2009, 19:48
Re: autonomus mode
1) it does use four motors in teleoperated
2)i changed the basic robot to have three joysticks. one to control two sides one to control the the othere two
3)i do not know how to make it control all four in autonomous mode
4)all it is doing is moving the two motors on pwm 1 and 2
5)i do not get gregs advice
i am knew to labview please help
Unread 12-02-2009, 22:50
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: autonomus mode
Can you post your autonomous code (either a picture, or the actual VIs) so we can help you better?
Unread 12-02-2009, 23:27
Re: autonomus mode
The basic robot project only controls two motors. The only straightforward way to change that to control four motors is to replace the "open two motor drive" VI with an "open four motor drive" one. If you do that, the RobotDriveRef is supposed to automatically run four motors when you use any of the Drive, TankDrive, or ArcadeDrive VIs.
I don't understand your joystick description. You said three joysticks, but you only listed two, and I can't figure out what they're controlling from what you said.
Let's take a step back here. What exactly do you have these four motors connected to, both electrically and mechanically? Maybe we just don't have the right idea of what you're asking.
Unread 13-02-2009, 17:25
Re: autonomus mode
okay we have four black motors for our wheels. two on each side of the robot. on the right side we have 2 jaguars which are pwm 1 and 2. on the left we have 2 more jaguars which are pwm 3 and 4. if you want a pic of the code let me know and i will try to put it on here. otherwise go to
http://www.icerobotics.org/index.php...id=3&Itemid=50
that is the best pictures i can give you
please let me know if you want to see my code
Unread 14-02-2009, 08:40
Re: autonomus mode
At this point, I do need to look at your code in order to help you further. I specifically want to see how you are using the "Drive" VIs, and how that differs from the Basic Robot code you started with.
Unread 14-02-2009, 10:51
Re: autonomus mode
i will put my doe on here and mabey it will help just give me a while it is on another computer
autonomus mode tomy General Forum 2 09-02-2009 22:22
autonomus mode question? holyrollers Rules/Strategy 1 05-02-2006 16:56
Autonomus mode railerobotics Programming 1 24-01-2006 19:56
on the fly vex autonomus mode CmptrGk FIRST Tech Challenge 0 06-10-2005 21:58
autonomus mode zooballski Rules/Strategy 2 13-01-2005 17:23
