Go to Post Winning the robot part of the competition is not about learning or doing unneccesary work. It works just like "winning" in industry. - Max Lobovsky [more]
Unread 12-02-2009, 16:02
Zellboy Zellboy is offline
FRC #1203
Zellboy is an unknown quantity at this point
Limit Switch problem
We're trying to program a digital input with a limit switch. How do we set the if statement?
This is what we have so far
if(Clamplimit -> Get() > 0)
       s[0] -> Set(false);
       s[1] -> Set(true);
Is it correct?
Unread 12-02-2009, 16:43
Re: Limit Switch problem
How you write the if statement depends on what you want it to do.
What do you want it to do?
Unread 12-02-2009, 16:48
FRC #1203
We have a claw connected to solenoids 7 and 6. We want the limit switch to close the claw when it's hit
Unread 12-02-2009, 16:59
You just need to turn
if (limit_switch_active)
    activate_solenoid_6;
    activate_solenoid_7;
into real code that compiles.
Replace limit_switch_active with whatever it takes to read your limit switch. That's something like Clamplimit->Get(), right? Replace the activate_solenoid_# with whatever it takes to put your solenoids in the desired state. I don't know how you've instantiated your limit switch or your solenoids, and I don't know how they are wired, so I can't give you working code to copy and paste.
I assume you'll want some way to open the claw later, right?
Unread 12-02-2009, 17:21
FRC #1203
This is how we have it set up
DigitalInput *Clamplimit;     //Limit Switch for clamp
Clamplimit = new DigitalInput(2); //Limit Switch for clamp (Digital Input)
if(Clamplimit)
       s[6] -> Set(false);
       s[7] -> Set(true);
Will this work as is?
Unread 12-02-2009, 19:38
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
No, it needs to be:
if(Clamplimit->Get())
       s[6] -> Set(false);
       s[7] -> Set(true);
Also, what class is s an instance of?
Which badges can you claim?
limit switch solomason519 Programming 9 09-02-2010 08:50
Limit Switch Problem Boydean Programming 3 13-02-2008 16:32
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
