Go to Post ...we might be able to take the 'out' out of 'outsourcing' - if we all share a strong cultural set of values, who exactly is 'out'? I think FIRST is a great way to do this, ... - Ian Mackenzie [more]
Unread 12-02-2009, 17:29
Megy698 Megy698 is offline
AKA: Meghann Mingle
FRC #0698 (Division By Zero)
Megy698 is an unknown quantity at this point
Crab Drive Programming!!! HELP!!!!!!!!!
Hey, all you Robo Peoples..
My team (698) needs a bit of help programming our crab drive system on LabVIEW.
What we need help is how to program it to drive.
Any help we could get would be amazing!!
THANK YOU!!!!
Unread 12-02-2009, 17:42
AdamHeard's Avatar
Lead Mentor
Re: Crab Drive Programming!!! HELP!!!!!!!!!
Give us some more details as to what you have so far.
Are you saying that you built a crab, and have no code whatsoever (nor an idea of where to start?).
Or are you saying you have something started, but it's not working?
If you give us more details, we'll be able to help you probably.
Unread 12-02-2009, 17:47
AKA: Meghann Mingle
The crab programming has difficult, all of our programmers are rookies, and we have very little idea of where to start. Currently we are trying to code the poteniometers so that way they can line up with the values for the joysticks. Mainly, we need help on the crab drive.
We have very little programming for the crab drive. At this point, any advice or ideas would be appericated.
Unread 12-02-2009, 17:59
AdamHeard's Avatar
Lead Mentor
All right, can you describe the phsyical nature of it in entirety? or better yet, post a picture of the drive?
To fully explain it, we'll need to know how it's driven (motors in the modules? motors in seperate gearboxes? two wheels per motor? a single motor per wheel?) and how it's steered. We'll also need to know what sensors are where.
Unread 12-02-2009, 18:19
AKA: Meghann Mingle
Here are two pictures:
Unread 13-02-2009, 00:54
chmp09 chmp09 is offline
AKA: Marc Pulte
FRC #1702 (Robocubs)
chmp09 is a jewel in the roughchmp09 is a jewel in the roughchmp09 is a jewel in the rough
I have not worked on a crab drive software before, but I can at least get you started with the pots. They need to be connected to analogue inputs (slot 1 by default). When programming, use the analogue input get voltage vi.
The voltage should correspond to what direction the pot is facing in. I recommend changing the values as they are imputed so that the read radians (multiply the value by 2PI/5), and the subtracting or adding so that all your values point to the same direction.
Unread 13-02-2009, 07:53
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Ok.
First, write up how it should work.
1. Driver pushes joystick in a direction.
2. Robot takes that direction and changes it to an encoder value.
3. Robot turns wheels to that encoder value.
Next, start iterating that write up, adding details as you go.
1. Drive pushes joystick in a direction.
A. How will we measure that angle? (in Degrees)
B. How do we make sure that when the robot turns, we keep track of how much and keep it relative to the joystick? (Gyro)
Iterate again
i. We can use the labview .vi that changes rectangular coordinates
to polar to give us the angle and magnitude of the joystick.
i. We'll need to somehow know the angle the robot starts relative to
the field, add that to the gyro, then keep that relative to the
joystick position
A. Angle / 360 * counts in one rotation of encoder
A. PID loop
This is how I teach our team to program. It's kind of a verbal flowchart, but it helps you think through the program very systematically. If, at any point, you start getting confused on what you need to do, then you probably haven't broken it down far enough.
I am going to warn you though - programming a crab drive is NOT a trivial task by any means. Probably at this point your easiest bet would be to remove one of the globe motors, connect both the front wheels by the same chain so they are turned together, and use one joystick for speed of the wheels, and the other to turn them left/right.
Programming Help- 2 Motor 2 joystick Drive System OMAR_567 Programming 2 02-02-2008 14:08
Crab Drive HELP!!*** GGCO Technical Discussion 18 08-01-2008 19:27
Crab Drive nukelear1991 Programming 13 21-12-2007 18:02
HELP?!? with Omnidirectional/Crab Drive KMAC42 Technical Discussion 8 09-01-2007 21:34
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
